Inventor Forum
Install error Failure occurred when attaching InventorStandardContent library
5 REPLIES 5
225 Views, 5 Replies
Can anyone tell if this is a problem & how to resolve?
I'm getting following error upon re-install of IV10 after just uninstalling
"Process return code 2: Failure occurred when attaching
Please see
C:Document...\Admin...\Locals\Temp\AttachLibrary_exe.InventorStandardContent
.log"
I can't find any InventorStandardContent.log file on my computer. I can
complete the install but I don't want any surprises later.
All was well with my first install of vanilla IV10. The error first happened
during online SP1 install (not from a file) after I interrupted the SP1
install & clicked to install the SP1 again.
Gary
5 REPLIES 5
Well, I went ahead & installed all 3 SP's anyway.
Guess I'll find out if there will be any issues with using the content
library. Sure would like to know if that error was benign though.
Gary
If the uninstall completed successfully, then a reinstall should have worked
without the error.
My recommendation is to see if the content is still available after
installing the SPs. The logs should be available at %TEMP%.
Jeff
"Gary Cross ( IV10 SP2)" wrote in message
news:5058007@discussion.autodesk.com...
Gary
Jeff,
There's no sign of content in temp directory. What should I check to see if
the install is ok? I assume the message was just related to the Content
Library, correct?
Gary
Uninstall MS SQL - Inventor content, then go into :\Program files\
find the MS SQL directory and delete the Inventor content database.
John Elliott - Autodesk
news:5058114@discussion.autodesk.com...
Jeff,
Library, correct?
Gary
Could you tell me if you were able to resolve the problem "Re: Install error Failure occurred when attaching InventorStandardContent library" and how?
Thanks.
