Inventor Forum
inserted parts in assembly don't move
6 REPLIES 6
Karol-Or
1729 Views, 6 Replies
I insert parts in an assembly, new parts from content center or from a library, without projected edjes, they are free to move until i impose the first constraint, the axis to axis alignment of round parts, then i cannot move them anymore in order to continue constraining them
6 REPLIES 6
scottmoyse
in reply to: Karol-Or
can you upload a dataset as an example?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Karol-Or
in reply to: scottmoyse
The handle has one constraint on the axis but cannot move
bob_holland
Karol-Or,
I took a look at your assembly and it seems to be missing some files.
I tested the two parts in a different assembly that I expect that you want to rotate.
You might want to try doing a pack and go w/o libraries and zipping that up and I can take a look at it.
Thank you.
Bob Holland
Autodesk Product Support
Karol-Or
in reply to: bob_holland
I opened the assembly file that i sent to you and it doesn't need more files.
I copied the files to a different folder and opened the assembly from there now, and the handle is free to move, as i expected.
Why, in the first place, was it locked, and now free to move, according to the constraints?
Millehuse
I've seen this behaviour a couple of times in our office - usually it's because the assembly is "sick" somewhere. Either a constraint that's conflicting, or something else un-resolved.
Exact same behaviour - insert any part ... it's free to move ... add 1 contraint and the part "locks-up".
Check for the "red-plus-I'm-sick-sign" up top - and see if anything is wrong.
T.Wiesendanger
in reply to: Millehuse
We got the same Problem with an assembly. But there is no red plus sign. It looks like its completly fine.
Any News on this? It looks like a lot of People have this Problem.
Kind regards
Tobias
