Inventor Forum
Insert Part using Ilogic
2 REPLIES 2
4444 Views, 2 Replies
I would like to use Ilogic to insert a part into an assembly I have found the basic rule but what changes do i need to make to get it to put the selected part into an assembly.
DimoFileDlgAsinventor.FileDialog=NothingInventorVb.Application.CreateFileDialog(oFileDlg)'oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
'oFileDlg.Filter = "XML Files (*.xml)|*.xml"
'oFileDlg.Filter = "Excel Files (*.xls;*.xlsx)|*.xls;*.xlsx"
'oFileDlg.Filter = "Text Files (*.txt;*.csv)|*.txt;*.csv"
'oFileDlg.Filter = "SAT Files (*.sat)|*.sat"
'oFileDlg.Filter = "IGES Files (*.igs)|*.igs"oFileDlg.Filter="Step Files (*.stp)|*.stp"'oFileDlg.DialogTitle = "Select a File"oFileDlg.InitialDirectory=ThisDoc.PathoFileDlg.CancelError=TrueOnErrorResumeNextoFileDlg.ShowOpen()IfErr.Number<>0ThenMessageBox.Show("File not chosen.", "Dialog Cancellation")ElseIfoFileDlg.FileName<>""Thenselectedfile=oFileDlg.FileNameMessageBox.Show("File "&selectedfile&" was selected.", "Dialog Selection Made")EndIf
Any ideas would be appreciated
Cheers
Chris Rodway
2 REPLIES 2
Curtis_Waguespack
Hi chrisrodway,
There is an example zip file showing the use of iLogic to place and replace components in an assembly at this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/ilogic-part-insertion/m-p/3667380#M451815
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Thanks for the reply,
The link is helpful and is helping me to understand ilogic more.
But for my situation it would be better if you could select a file in the file selection dialogue (in this case a surface in iges format) and be placed in the part file. This surface is then used to reference features to build the part, which I am aiming to do in Ilogic as well.
Is this possible
Chris Rodway
