can i import parts into multi body IPTs,or does it have to be an Assembly
I need to add a purchased part into the design.
Chris
Inv 2010
Solved by Curtis_Waguespack. Go to Solution.
Solved by cwhetten. Go to Solution.
You can't do it in the same way as an assembly, but it can be done. You can use the Derive command to bring the solid body of one part into another part (derive it as a separate solid body). Then you will have to use the Move Body command to move and rotate it into the desired location.
Hi pgcust,
Another way to do this is to:
This allows you to position the part first, but doesn't create a derived link. So if you need that live link cwhetten's Derived approach might be the better way to go, if not the Copy Object method will likely work best.
I hope this helps.
Curtis
