I am relatively new to dynamic simulation so it is quite possible I am doing something incorrectly. I am trying to insert a revolution joint into my assembly but it seems it does not exist. I have attached two screenshots. One is from a tutorial I am going through which contains a longer list of available joints. (More.png) The other is the assembly I am working on which contains less available joints. (Less.png) Could somebody please explain what is going on?
Rob
Solved by RobJV. Go to Solution.
