Greetings everyone,
I'm trying to do what I describe in the subject but thus far I wasn't able to find a way. Can anyone suggest me anything?
Thank you in advance
Solved by Curtis_Waguespack. Go to Solution.
Do you mean like this ?
Then all the information you need is here http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-97753A27-FCD6-4037-8DF4-E999A39783AE
DON'T FORGET TO SAVE YOUR NEW TEMPLATE, you may need to search around to find the correct location of the templates files on your system as it may differ from my or other users.A typically standalone installation they are found here : C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates
Hi ApostolosJK ,
This link has an iLogic example for inserting an image into a title block:
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
