Inventor Forum
Insert image into title block using the API
3 REPLIES 3
696 Views, 3 Replies
Greetings everyone,
I'm trying to do what I describe in the subject but thus far I wasn't able to find a way. Can anyone suggest me anything?
Thank you in advance
3 REPLIES 3
Paul-Mason
Do you mean like this ?
Then all the information you need is here http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-97753A27-FCD6-4037-8DF4-E999A39783AE
DON'T FORGET TO SAVE YOUR NEW TEMPLATE, you may need to search around to find the correct location of the templates files on your system as it may differ from my or other users.A typically standalone installation they are found here : C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Curtis_Waguespack
Hi ApostolosJK ,
This link has an iLogic example for inserting an image into a title block:
http://forums.autodesk.com/t5/Inventor-Customization/Constraining-JPG-Logo-in-a-title-block/m-p/5025...
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
@Mason-Paul: Yes that's what I want to achieve but rather doing it by hand, I want to do it using the API.
@Curtis_Waguespack: Thank you. That's what I was searching for. (Actually the answer is quite straight forward... I didn't think about searching "logo insertion"....)
