Inventor General Discussion
Distinguished Contributor
achmidt
Message 1 of 8 (712 Views)
Insert an Excel into inventor drawing
712 Views, 7 Replies
11-20-2013 07:37 AM
Hi!
I`m trying to insert an excel spread sheet in to inventor drawing, for some reason inventor cuts off 2 last rows. Is there a limit of how many rows can be inserted ?
it cuts off these two: see attached.
13.2    45FT     R2440    Gasket Material Vinyl Foam Strip 2" wide x .125 thk., Black, Weather-Resistant
14    12 TUBES    C11272    CAULK, SILICONE - CLEAR
Alex
Inventor Virtual Parts Addin
http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3Avirtualpartsadd-in_windows32and64%3Aen
Distinguished Mentor
ccarreiras
Message 2 of 8 (709 Views)
Re: Insert an Excel into inventor drawing
11-20-2013 07:51 AM in reply to: achmidt
Hi!
It's working well in 2014.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
achmidt
Message 3 of 8 (701 Views)
11-20-2013 08:09 AM in reply to: ccarreiras
Well.... We are using 2012....
ccarreiras
Message 4 of 8 (692 Views)
11-20-2013 08:47 AM in reply to: achmidt
Hi!
Has to work also in 2012. Check if you are doing something wrong.
Check if you have installed all the updates for Inv2012.
Regards.
CarlosC
Windows 7 64Bit
achmidt
Message 5 of 8 (689 Views)
11-20-2013 08:50 AM in reply to: ccarreiras
Thank you, i tried 2 different ways using:
- Tools --> Paste Special
- Manage --> Insert Object
Both are cutting 2 last rows. Tried it on 3 different machines - same thing.
We use Inventor Suite 2012 64bit
Valued Mentor
mpatchus
Message 6 of 8 (665 Views)
11-20-2013 10:39 AM in reply to: achmidt
I seem to recall that at one point there was a limitation to the number of rows that could be imported.
Can't remember if it was for 2012 or not though.
Also check the Excel table for blank row or column.
From the 2012 HELP FILE....
NOTE:  Data is copied from the first worksheet only, starting at the specified cell.  When the source is an .xls or .csv file, data import stops when a blank row or column is encountered.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Valued Mentor
mpatchus
Message 7 of 8 (658 Views)
11-20-2013 11:16 AM in reply to: mpatchus
A couple of related posts I found...
http://forums.autodesk.com/t5/Inventor-General/Missing-rows-from-inserted-Excel-object/m-p/3499014/h...
http://forums.autodesk.com/t5/Inventor-General/Excel-BOM/td-p/3483948/highlight/true
Font size in the Excel spreadsheet seems to be a common culprit.
Mike Patchus
achmidt
Message 8 of 8 (652 Views)
11-20-2013 11:47 AM in reply to: mpatchus
Thank you. Changing font to a smaller font allows to bring entire sheet.
