How I can put a screw in a hole?, because this hole is in a cilindrical tube.
I tried many times but without success.
Please see attachment and look my problem.
One of the faces already have a screw, but in the tube I can't.
Inventor 2011.
Solved by coreyparks. Go to Solution.
Add an axis to axis mate constraint and then make the bottom tapered sdie of the bolt head tangent to the c'sunk portion of the hole. Should work just fine.
