Inventor Forum
Input on Center of Gravity Param Use
17 REPLIES 17
Message 1 of 18
wimann
2068 Views, 17 Replies
So I found a while ago, on this forum, how to get the center of gravity values from iproperties and assign them to user parameters using iLogic:
cgx = iproperties.centerofgravity.x
cgy = iproperties.centerofgravity.y
cgz = iproperties.centerofgravity.z
ilogicvb.updatewhendone = true
I would like to have a work point follow my cg values in the model. The only way I can think that could do this is to by offsetting 3 work planes using the user parameters as offsets. This is so because the values retuned are sometimes negative. Therefore, I don't think (I'm about 99% certain) that I could not do this through sketches but I don't like to crowd my models with unneccessary user work planes. And even if I could do this with sketches, I don't know that I would want a bunch of sketches either.
So what I'm looking for is the cleanest way that I can create a work point in 3D space with the ability to travel in a negative direction given the x,y,z coordinates.
Any ideas guys?
EDIT: I'm considering this for both parts and assemblies, so if a 3d sketch would work for a part file, it can't be used for an assembly.
Thanks a ton.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
17 REPLIES 17
Message 2 of 18
cwhetten
in reply to: wimann
Hi Will,
If you're using iLogic anyway, our approach might work for you.  We use a rule that checks to see if a workpoint exists already (it checks by the name of the feature, which we have called "Shipping Center Of Gravity", defined on line 27 of the rule).  If it exists, it updates its location to the CoG coordinates.
If the workpoint does not yet exist, it creates it.  It is a fixed workpoint that doesn't rely on other work features for its location.  It's location is solely controlled by the iLogic rule.  Spoilered below is the rule:
Spoiler
Option Explicit On
    ' Check to make sure a part or assembly document is active.
    Dim doc as Document = ThisDoc.Document
    If doc.DocumentType <> DocumentTypeEnum.kPartDocumentObject AndAlso doc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        MessageBox.Show(" This rule can only be run in a part or assembly.", "WorkPoint At Mass Center")
        Exit Sub
    End If
    Dim massProps As MassProperties
    Dim workPoints As WorkPoints
    If (doc.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
      Dim partDoc as PartDocument = doc
      massProps = partDoc.ComponentDefinition.MassProperties
      workPoints = partDoc.ComponentDefinition.WorkPoints
    Else
      Dim assemDoc as AssemblyDocument = doc
      massProps = assemDoc.ComponentDefinition.MassProperties
      workPoints = assemDoc.ComponentDefinition.WorkPoints
    End If
    ' Get the Center of Mass.
    Dim oCenterOfMass As Point = massProps.CenterOfMass
    ' Check to see if a work point for center of mass already exists.
    ' This uses the name of the work feature to identify it.
    Const workPointName As String = "Shipping Center Of Gravity"
    Dim oWorkPoint As WorkPoint
    Try
        oWorkPoint = workPoints.Item(workPointName)
    Catch
        oWorkPoint = Nothing
    End Try
    If (oWorkPoint IsNot Nothing) Then
                Dim oFixedDef As FixedWorkPointDef = oWorkPoint.Definition
                oFixedDef.Point = oCenterOfMass
        Else
                Dim oFixedDef As AssemblyWorkPointDef = oWorkPoint.Definition
        End If
        doc.Update
    Else
        ' Create a new workpoint at the location of the center of mass.
        oWorkPoint = workPoints.AddFixed(oCenterOfMass)
        ' Rename the work point.
        oWorkPoint.Name = workPointName
    End If
Cameron Whetten
Inventor 2014
Message 3 of 18
wimann
in reply to: cwhetten
First off, thank you so much. That looks like a huge step in the right direction. I really wish I understoon iLogic/Inventor VBA better so that I could generate these things on my own. I do have a few questions pertaining to your rule though.
So this rule would be created as an external rule and run by the user when desired. What I would really like to do with this is pre-write it into our part and assembly templates. And what I'd really like for it to do is update as new parts are placed and moved/re-constrained rather than the options in the event triggers. For part files, the "Any Model Parameter Change" Event Trigger would probably suffice. The idea is to create as little interaction with iLogic as possible for the end user. Currently, I am the most familiar with iLogic at my place of work by a long shot. I mean... if my coworkers know the term "iLogic", they're in good shape. With that in mind, I want this to be as hands free as possible.
So, if I'm cleared to have a work point pre-existing in our templates named (in all likelihood) "Center of Gravity", then I will simply have it pre-existing for any new part or assemblies created moving forward. However, if that's not possible, then I would probably want to make a button for the ribbon that would create the work point. There's also the issue with user settings and making sure that my co-workers also have access to said button. I'm not certain if I'd have any complications with that cause I haven't tried it out yet.
Thanks again.
-Will Mann
Message 4 of 18
wimann
in reply to: wimann
By the way, as far as I'm concerned, your solution does everything I need it to lol. I'm just trying to make it end user friendly.
-Will Mann
Message 5 of 18
wimann
Cameron,
Through trying out the external rule you provided, I've found that when it is placed in a part file, the point is placed and grounded, however when it is placed in an assembly, the point is placed and left capable of moving.
I'm looking through your code but I'm not familiar with how to make the same thing happen for an assembly.
Any thoughts?
-Will Mann
Message 6 of 18
wimann
in reply to: wimann
Nevermind Cam,
I just added "oWorkPoint.Grounded = True" to the tail end of both the portion of the code that updates the workpoint as well as the portion that creates.
-Will Mann
Message 7 of 18
cwhetten
in reply to: wimann
Hi Will, I am glad to help.
You say the point is left capable of moving.  In my experience, it hasn't been a problem, but have you seen it move unexpectedly?  I'm not sure how that would happen, but if it does, I would like to know how so I can prevent it from happening in my models.
As for getting the code to automatically run in an assembly when placing & constraining components, that's not so easy.  We trigger it from our configuration rules, so it works for us.  It is possible in Visual Basic to write code that watches for specific events and then runs other code accordingly, but I don't have the skills to do this.
You could set up a command button on the ribbon in a couple of ways.  Firstly, you could place the code as a macro in Inventor's VBA project file (default.ivb).  This would be instead of an external rule.  It is possible to add VBA macros as buttons on the ribbon (through Tools > Customize > Ribbon tab).  The code would need to be slightly rewritten, as there are a few syntax differences between VBA and iLogic (which is based on VB.NET).
Secondly, you could use Visual Basic Express (a free version of the VB.NET programming environment) to create a plugin version of this code.  It is possible with plugins to add custom command buttons to the ribbon anywhere you like, and you can make a custom icon for your command button.  This way, it integrates nicely and looks like it was always meant to be there.  This method entails quite a bit more work, but when done properly it looks really nice and is easy to deploy to many workstations.
Cameron Whetten
Inventor 2014
Message 8 of 18
wimann
Cam,
So after some more use, I'm finding that the macro I used to run the external rule is causing inventor to crash upon execution. I'm not too sure what is causing the problem. Originally I copied the macro from an old post in the Inventor Customization Forum. The code is as below:
Public Sub CenterofGravity()
  RuniLogic "CenterOfGravity"
End Sub
Public Sub RuniLogic(ByVal RuleName As String)
  Dim iLogicAuto As Object
  Dim oDoc As Document
  Set oDoc = ThisApplication.ActiveDocument
  If oDoc Is Nothing Then
    MsgBox "Missing Inventor Document"
    Exit Sub
  End If
  Set iLogicAuto = GetiLogicAddin(ThisApplication)
  If (iLogicAuto Is Nothing) Then Exit Sub
  iLogicAuto.RunExternalRule oDoc, RuleName
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
Set addIns = oApplication.ApplicationAddIns
'Find the add-in you are looking for
Dim addIn As ApplicationAddIn
On Error GoTo NotFound
Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
If (addIn Is Nothing) Then Exit Function
addIn.Activate
Set GetiLogicAddin = addIn.Automation
Exit Function
NotFound:
End Function
I'm primarily confused because it worked initially, and with no apparent changes, is now crashing inventor.
You mentioned that the code would need to be altered in order to make the macro handle everything without the external rule, not to ask too much of you, but how would that work? The external rule, as I currently have it, looks like this:
Option Explicit On
        Exit Sub
    End If
    Else
    End If
    Const workPointName As String = "Center Of Gravity"
    Try
    Catch
    End Try
        Else
        End If
        doc.Update
    Else
    End If
-Will Mann
Message 9 of 18
cwhetten
in reply to: wimann
Hi Will.
The VBA version is spoilered below (also attached as a TXT file).
Spoiler
Sub CoGTest1()
    Dim doc As Document
    Set doc = ThisDocument
    If doc.DocumentType <> DocumentTypeEnum.kPartDocumentObject And doc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        xx = MsgBox(" This rule can only be run in a part or assembly.", , "WorkPoint At Mass Center")
        Exit Sub
    End If
    Dim workPoints As workPoints
    If doc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
      Dim partDoc As PartDocument
      Set partDoc = doc
      Set massProps = partDoc.ComponentDefinition.MassProperties
      Set workPoints = partDoc.ComponentDefinition.workPoints
    Else
      Dim assemDoc As AssemblyDocument
      Set assemDoc = doc
      Set massProps = assemDoc.ComponentDefinition.MassProperties
      Set workPoints = assemDoc.ComponentDefinition.workPoints
    End If
    Set oCenterOfMass = massProps.CenterOfMass
    'Try-Catch statements are a VB.NET thing and don't work in VBA.
    'We will test for existing workpoint in the following way instead.
    Dim bPointExists As Boolean
    Let bPointExists = False
    Dim oTestPoint As WorkPoint
    For Each oTestPoint In workPoints
        If oTestPoint.Name = workPointName Then
            bPointExists = True
            Exit For
        End If
    Next
    If bPointExists Then
        Set oWorkPoint = workPoints.Item(workPointName)
                Dim oPartFixedDef As FixedWorkPointDef
                Set oPartFixedDef = oWorkPoint.Definition
                Let oPartFixedDef.Point = oCenterOfMass
        Else
                Dim oAssemFixedDef As AssemblyWorkPointDef
                Set oAssemFixedDef = oWorkPoint.Definition
                Let oAssemFixedDef.Point = oCenterOfMass
        End If
        doc.Update
        Let oWorkPoint.Grounded = True
    Else
        Set oWorkPoint = workPoints.AddFixed(oCenterOfMass)
        Let oWorkPoint.Name = workPointName
    End If
End Sub
The differences between the VBA and iLogic versions are mostly in the use of Set and Let statements.  Also, the Try-catch statement that I was using to test if the workpoint already exists had to be removed.  Try-catch statements are a VB.NET thing and don't work in VBA.  So I replaced it with a for each loop to test if any existing workpoints had the same name.  There were a few other syntactic changes, but you can compare the two versions to find them all (fun game and free to play!).
As for the crashing, I don't know why it would start doing that.  But, if you use the VBA version of the rule, you won't need the crashy macro that runs the iLogic rule anymore.
Cameron Whetten
Inventor 2014
Message 10 of 18
wimann
Cameron,
I'm getting an error on line 4 when I try to run the macro.
Whatcha think?
Thanks again for all of your help,
-Will Mann
Message 11 of 18
cwhetten
in reply to: wimann
Do you have a document active when you run the macro?
Message 12 of 18
wimann
Yeah, I tried running it in a regular 'ol assembly. Also just now in a part file:
-Will Mann
Message 13 of 18
cwhetten
in reply to: wimann
Did you add the macro to your default.ivb?  I forgot that I suggested to do that.
Try replacing the line that says
with this:
Set doc = ThisApplication.ActiveDocument
Message 14 of 18
wimann
Yessir.
-Will Mann
Message 15 of 18
cwhetten
in reply to: wimann
You responded to quickly!  Smiley Very Happy  See my edit above.
Message 16 of 18
wimann
lol so I did.
That seems to have done the trick. No lie - I thought about that. I've seen that line of text a few times before but, again, I don't know enough about it to know that ThisApplication.ActiveDocument was actually what I needed.
Thanks again Cameron.
-Will Mann
Message 17 of 18
cwhetten
in reply to: wimann
ThisDocument accesses the document object that contains the VBA code.  In the file I was using to test the code, I had just added it to an assembly VBA project, so it would get the assembly document and it worked just fine.
However, when the code is contained in the application project (default.ivb), then ThisDocument returns nothing (the code isn't contained in a document so there is no document to return).  That's why we have to get the document another way.  The easiest way to do that is with ThisApplication.ActiveDocument.
However, I have learned that ThisApplication.ActiveDocument is not always the best way.  Sometimes you want to run a routine on another document besides the active one, so using ThisApplication.ActiveDocument will return the wrong document object.  Hopefully that made some sense...
Cameron Whetten
Inventor 2014
Message 18 of 18
wimann
That makes perfect sense.
-Will Mann
