I want to constrain two parts to rotate about the same axis. One fixed and one to rotate by a specified indexed amount. For example to rotate in 60 degree increments. This would make the part rotate around a center 360 degrees but in 60 degree increments only.
Solved by MariaManuela. Go to Solution.
Drive Constraint tool????
That might work actually. Set the increment to 60deg. You wont be able to drag the component to show movement though.
What type of constaint is being driven by your screen shot. I have two parts that rotate around a common axis. What type of constraint do I need?
Angle constraint...between two planes passing through the both axis.
