Inventor General Discussion
Active Member
JeremyEccleston
Message 1 of 4 (236 Views)
Incremental dimensions with a minimum
236 Views, 3 Replies
04-10-2012 12:14 PM
I am new to Inventor and maybe biting off more than I can chew, but I am trying to set up a dimension that starts at a minimum value and increases incrementally by 1/16" of an inch to satisfy another dimension.  I've attached a pdf showing the part and the two dimensions.  I need the overall thickness of the part to start at 1 1/4" as shown and as the width (Depth + 1 1/2") changes, the thickness will grow when the tongue of the part gets less than 5/8".  I'm guessing this is an area best suited to ILogic, but I'm not sure how to get started.  Can anyone help, please?
Sorry forgot to post the video
http://video.answers.com/how-to-use-dimensions-in-autodesk-inventor-2011-299992420
How many different configurations will you have? You are making this an ipart right?
mcgyvr
Message 2 of 4 (225 Views)
Re: Incremental dimensions with a minimum
04-10-2012 12:50 PM in reply to: JeremyEccleston
You can do dimension equations/expressions in Inventor..
Watch this video.. Somewhere around the 2:45 second mark they start showing how to put equations/expressions into the dimension box..
Then
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0733-Design_O733/Functions%2c_pr...
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Active Member
JeremyEccleston
Message 3 of 4 (211 Views)
04-10-2012 01:11 PM in reply to: mcgyvr
Thank you for looking at my question.  I'm not quite sure how to apply your suggestion.  I also don't see a video.  Maybe it's being blocked on our end, but normally there is a warning box that it was blocked.  I have an expression already in the one dimension field.  It is grabbing the "depth" dimension from another part and adding 1 1/2" to it.  I tried to do something like an IF/THEN statement that I would use in Excel, but that stayed red and would accept.  I also don't know how to make it adjust in 1/16" increments.  Maybe you could show me an example of what you're thinking?
mcgyvr
Message 4 of 4 (204 Views)
04-10-2012 01:41 PM in reply to: JeremyEccleston
Windows 7 64 bit
