Inventor Forum
incorrect radial section view : section particpation none
6 REPLIES 6
771 Views, 6 Replies
Please go through attachment,
The section view behaves strangely with the ‘section participation: none’ components
Invertor2012 sp2
Win7 x64
Regards
Sachin
6 REPLIES 6
Cadmanto
Sachin,
I respectfully disagree.  If this is a true section then the nut should be hatched and showing a shorter width on the left side with out seeing the hex and showing a through hole.
Is this nut model created by you or is it from the content center?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
JDMather
in reply to: Cadmanto
@Cadmanto wrote:
.....If this is a true section then the nut should be hatched .....
It is common practice to have fasteners and shafts NOT sectioned in a section view like this.
I haven't tried to reproduce this issue, but Inventor has functionality that is supposed to handle this common practice.
Cadmanto
in reply to: JDMather
Yes, that is true.  But I have had the issue where the CC parts do not section in which case I edit the view
and select this.  Then it shows the hatching fine.
Best Regards,
Scott McFadden
No, this doesn’t solve my problem and neither the replies are the solution for me.
Please get it correct
1. I don’t want shown nut to be sectioned.
2. Consider section AOA ie AA is section line and O is intermediate point; when section AA placed it overlaps the non sectioned components from both segments of same section line ie from AO as well as OA
Kindly note I am using Inventor from Inventor 6 and till now continuously using it.
Before posting this thread i roughly searched the forum as well as gone through updates and hot fixes
Thank you
Sachin.
jan.miskanin
Hi Sachin,
this is already known and is logged in our tracking system as #1462858.
Jan
Cadmanto
If you are using Inventor 2006 I can't speak to that version.  I started using it in 2011.
The only other thing I can suggest would be to play with the display settings of that view under
the "Edit View" command to see if that gives you better results.
It really doesn't do you any good to post the files seeing the vast majority of users here are well past that version.
Best Regards,
Scott McFadden
