Good day
I’m used to working in mm in Inventor 2015, I want to know what is the correct input method for inch?
When I’m working in the *.ipt , I add a length of 2 Feet 3 Inch as 2’ 3” in the dialog box – and it shows correct as 2’-3”
But when I want to add a length of 2 Feet 3 and ½ Inch as 2’ 3”+1/2 in the dialog box – then it shows as 27.500 . The 27.500 is now converted, still in Inches, but I would like to see 2’-3 ½“
What is the correct input method for inch?
Regards
Solved by JDMather. Go to Solution.
Try this entry.
or
