I start a new assembly, name it 2600-KPL and I add three other assemblies to it. It looks like this in the tree:
2600 - KPL.iam
- BU200.iam
- BU0034.iam
- BU0202.iam
In the files starting B there are several part files. I would like to make it that the file name 2600 - KPL only contains the part files of the respective 3 assemblies and not just those three files.
So instead of having just three files I would have something like 25 part files. I hope you understood what I meant by that? Is that possible or do I have to make a completely different assembly?
Solved by mcgyvr. Go to Solution.
Would you like to retain the "B" assemblies for use in another product?
Personally choice #1 is probably the best solution.
You have 2 options.
#1-Set all the "B" assemblies in that 2600-KPL assembly as "phantom". That will push all the parts up into the upper level parts list.
#2-"demote" the subassemblies which will remove the subassembly completely and leave you with just the parts.
Nice thing about the phantom is that you can keep the parts in a sub for ease of reuse and more than likely if you have an ERP system it will support phantom subassemblies just like Inventor does.
@Anonymous wrote:
I don't want to sound like an idiot here but I'm trying to make it Phantom but it doesn't work.
I go into Tools/Document Setting/BOM and choose Phantom. But is that wrong? Nothing happens.
You did that in the "B" subassembly files right? If so.... Now create a drawing of the 2600kpl assembly, place a parts list and you will see the difference. (all the parts in the b subs will show up now versus the B subassembly part numbers.
FYI.. doing what you did makes the "B" subassemblies ALWAYS non-stocking subassemblies and their components will always be pushed into the upper level parts list..
If thats what you want then good..
If you just want those parts in the "B" subs to be in just the 2600kpl sub but remain subassemblies in all other upper level assemblies then you want to "demote" in the 2600kpl assembly only.
@Anonymous wrote:
Ah ok. Now I get it. Thanks!
However I didn't just want that in the drawing. I wanted that in the actual assembly file as well. So instead of the 3 assemlies I'll just have a tree with 25 part files.
Then as I said above.. "demote"..
Right click on the sub...component flyouy.. demote button
