In your model document settings you can change it here.
I would also change it in each of your part and assembly model templates.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
If you want to know how to crop an image, as long as you are using windows 7 there is a tool called the "Snip Tool"
which will give you the ability to crop screen shots. Save it as a jpg file and insert it into your posting.
I found it, I was in the drawing not the model, but mine is set to three places but when I bring the model into the drawing and dimension it it is still at two places
any more ideas, isn't there a way to change the style or Ansi standard to show 3 place precision then when I bring in the model to the IDW it dimension as 3 places and also when I add the hole table it also has 3 places in each column, including the description column that shows diameter
Sorry, my system crashed.
What I showed you will work for your model templates, but if you are looking for the drawing you are going to have to either change an existing dimension style or create a new one here with the correct settings you need.
As far as the hole table, I don't use them, but check here to see if this thread helps you.
http://208.74.205.69/t5/Inventor-General/Hole-Table-Precision/td-p/1756394
All good, and Thank you by the way
What I need is: When I bring the model into the drawing and dimension the part I want it to have 3 place precision and also when I bring the hole table in I want all of it to have 3 place precision.
