Inventor Forum
Improved the Measure Sweep Code
1 REPLY 1
DeerSpotter
650 Views, 1 Reply
Original post: http://beinginventive.typepad.com/being-inventive/2011/09/loop-length-of-a-sweep-as-custom-parameter...
Modified Code:
 'Set a reference to the strings
Dim propertyName7 As String = InputBox("Enter Sweep Name", "Calculate Sweep Length", "Fill in sweep name (case sensitive) see in feature tree")
Dim propertyName8 As String = InputRadioBox("What are the Units?", "mm", "in", False, "Pick the Units")
If propertyName8 = True Then
propertyName8 = " mm"
Else
propertyName8 = " in"
 'Set a reference to the active part document
    Dim oDoc As PartDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    oDef = oDoc.ComponentDefinition
    Dim opath As Path
    opath = oDef.Features.SweepFeatures.Item(propertyName7).Path
    Dim TotalLength As Double
    TotalLength = 0
    Dim oCurve As Object
    Dim i As Integer
    For i = 1 To opath.Count
        oCurve = opath.Item(i).Curve
        Dim oCurveEval As CurveEvaluator
        oCurveEval = oCurve.Evaluator
        Dim MinParam As Double
        Dim MaxParam As Double
        Dim length As Double
        Call oCurveEval.GetParamExtents(MinParam, MaxParam)
        Call oCurveEval.GetLengthAtParam(MinParam, MaxParam, length)
        TotalLength = TotalLength + length
    Next i
    Dim oparams As Parameters
    Dim oparam As Parameter
    oparams = oDoc.ComponentDefinition.Parameters
    Dim exists As Boolean
    exists = False
    'Find out if parameter exists
    For Each oparam In oparams
    If oparam.Name = "Sweeplength" Then exists = True
    Next oparam
    'Change the value if the parameter exists otherwise add the parameter
    If exists Then
        oparams.Item("Sweeplength").Value = TotalLength
    Else
        oparams.UserParameters.AddByValue( "Sweeplength", TotalLength, 11266)
    oDoc.Update
MessageBox.Show(Parameter("Sweeplength")& (propertyName8), "Total Sweep Length")
 you can now input which sweeps you have.
If somebody can help me somehow to be able to select multiple sweeps that would be great!
im also going to try to have the code detect the units, and automatically convert it into mm or inches depending the user input.
Thanks!
Max
Image and video hosting by TinyPic
See My LinkedIn Profile
1 REPLY 1
DeerSpotter
in reply to: DeerSpotter
Added The Change units parameters, still need to sync first question with the rest. 😕
'furom link: http://forums.autodesk.com/t5/Inventor-General/Improved-the-Measure-Sweep-Code/td-p/4782187
Else
'------- start of change units ------
question = MessageBox.Show("Are you sure you want to change the units of measure?", _
"iLogic",MessageBoxButtons.YesNo)
If question = vbNo Then
Return
Else
            'get input from user
                oUnit = InputRadioBox("Select a units of measure type", "Metric", "Imperial", True, "ilogic")
            'create precision value list
                oPrecisionArray = New String(){0, 1, 2, 3, 4, 5}
                oPrecision = InputListBox("Select the number of decimal places to use for the units of length display.",  _
                oPrecisionArray, 3, "iLogic", "Decimal Places ")
            'example UnitsTypeEnum Enumerators
                'kCentimeterLengthUnits = 11268
                'kMillimeterLengthUnits = 11269
                'kInchLengthUnits = 11272
                'kKilogramMassUnits = 11283
                'kGramMassUnits = 11284
                'kLbMassMassUnits = 11286
                                If oUnit = True Then
                        'set to millimeter
                                oUOM_1 = 11269
                        'set to kilogram
                                oUOM_2 = 11283
                        Else
                        'set to inch
                                oUOM_1 = 11272
                        'set to pounds mass
                                oUOM_2 = 11286
            'Define the open document
                Dim openDoc As Document
                openDoc = ThisDoc.Document
            'set length units for the top level assembly
                openDoc.unitsofmeasure.LengthUnits = oUOM_1
                'set mass units for the top level assembly
                openDoc.unitsofmeasure.MassUnits = oUOM_2
                'set precision
                openDoc.unitsofmeasure.LengthDisplayPrecision = oPrecision
                'Look at all of the files referenced in the open document
                Dim docFile As Document
                For Each docFile In openDoc.AllReferencedDocuments
                                'format  file name
                                Dim FNamePos As Long
                                FNamePos = InStrRev(docFile.FullFileName, "\", -1)
                        Dim docFName As String
                        docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
                        'set length units
                                docFile.unitsofmeasure.LengthUnits = oUOM_1
                                'set mass units
                                docFile.unitsofmeasure.MassUnits = oUOM_2
                                'set precision
                                docFile.unitsofmeasure.LengthDisplayPrecision = oPrecision
                                'rebuild to update the display
                                docFile.Rebuild
                Next
'update all
iLogicVb.UpdateWhenDone = True
'------- end of change units ------
    Dim opath As Path
    TotalLength = 0
    Dim i As Integer
    Next i
    exists = False
    Next oparam
    If exists Then
    Else
    oDoc.Update
 Let me know what you guys think 🙂
