Inventor General Discussion
Active Member
breichert
Message 1 of 12 (318 Views)
“Improper Argument
318 Views, 11 Replies
02-22-2013 12:42 PM
When opening files in Inventor 2013 we have a number of systems getting “Improper Argument” and then Inventor crashes.  We are running Building 176 of 2013 sp1.1
Is this a known issue?
I've attached one of the files causing the issue.
Brad
We are running Windows 7.
I was able to push everything except the following out through Group Policy:
HKEY_CURRENT_USER>SOFTWARE>AUTODESK
and it still didn't work.  I actually got an error about not being able to access the registry when Inventory was opened.  Any ideas how to push out hte setting above or why I got that message?
Brad
I finally figured out the issue was related to fodler permissions.  I'm not sure why it only affected some users and not others but here is what I found.
Student home folders are in:
\\server\homeshare\gradyear\username
Their my documents is mapped directly to the path above.  The students did not have adequate permissions to browse through the folders.  This doesn't cause a problem for MS Office or another apps we use but does Autodesk...  This seems like it could be addressed in a future code revision.
I granted rights to the rights to browse through the folders and the issue went away.
Brad
JDMather
Message 2 of 12 (312 Views)
Re: “Improper Argument
02-22-2013 01:00 PM in reply to: breichert
I was able to open the file and perform an Extrude without issue.  I have Update 2 installed.
Try going to Tools>Application Options>Hardware tab and set on lowest setting.  Does that help?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
breichert
Message 3 of 12 (301 Views)
Re: ?Improper Argument
02-22-2013 01:10 PM in reply to: JDMather
What version of inventor are you running? On what OS? Brad
JDMather
Message 4 of 12 (300 Views)
02-22-2013 01:16 PM in reply to: breichert
Information in my signature.  Added info to response that I also have Update 2.
Win 7 Home Premium
Active Member
breichert
Message 5 of 12 (276 Views)
02-22-2013 04:17 PM in reply to: JDMather
I'll tried your suggestion Monday.
Thanks!
Brad
Active Member
breichert
Message 6 of 12 (240 Views)
02-25-2013 09:05 AM in reply to: JDMather
I've already got it as low as it will go.
Brad
JDMather
Message 7 of 12 (236 Views)
02-25-2013 09:14 AM in reply to: breichert
I suspect that only your VAR sitting at your machines will be able to solve this problem.
Product Support
4donwan4
Message 8 of 12 (225 Views)
02-25-2013 01:38 PM in reply to: breichert
Can you verify if full permissions have been set to these folders? It is our best practice to allow users full permissions, but where this can't be done, Autodesk software needs full permission to:
Registry Entries:
HKEY_LOCAL_MACHINE>SOFTWARE>AUTODESK  *
Folders:
The folder the program was installed in c:\program files\AutoCAD 2011 (for example)
XP:
c:\documents and settings\all users\application data\Autodesk
c:\documents and settings\<the current user>\application data\Autodesk
c:\program files\common files\autodesk shared
c:\Program Files\Autodesk
Win7/Vista:
C:\Users\All Users\Autodesk
C:\Users\<the current user>\AppData\Local\Autodesk
C:\Users\<the current user>\AppData\Roaming\Autodesk
C:\Program Files\Common Files\Autodesk Shared
C:\Program Files\Autodesk *
C:\ProgramData\FLEXnet
C:\ProgramData\Autodesk
Active Member
breichert
Message 9 of 12 (214 Views)
02-25-2013 04:30 PM in reply to: 4donwan4
That looks like it might do the trick.  I'll give it a try in the morning.
Thanks!
Brad
Active Member
breichert
Message 10 of 12 (192 Views)
02-26-2013 02:40 AM in reply to: 4donwan4
Brad
