Inventor General Discussion
Active Member
sam_melvin
Message 1 of 8 (1,712 Views)
Importing Points
1712 Views, 7 Replies
03-21-2012 08:21 AM
Im trying to make a wing by importing the cross section coordinates into a 2D sketch.
I was originally importing spreadsheets made in open office but saved as .xlsx and .xls, but have since attempted it with .xls files created in excel.
Once I select a file to import and press OK, the pop-up window closes and then nothing happens. I have tried this numerous times with numerous different files, and with each type of import (point, line, splice).
The spreadsheets are properly formatted (see attached) and I have tried removing the scale and the x y z column titles, and I still got nothing.
Any suggestions would be muchly appreciated.
Sam
JDMather
Message 2 of 8 (1,707 Views)
Re: Importing Points
03-21-2012 08:26 AM in reply to: sam_melvin
What version of Inventor? 2010? 2011? 2012?  Have you installed all Service Packs for your version?
Attach you xls file here to see if it works for others.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
sam_melvin
Message 3 of 8 (1,679 Views)
03-22-2012 04:39 AM in reply to: sam_melvin
Im using AutoDesk Inventor Professional 2012, and I have installed service pack 1.
I've attached my xls file.
JDMather
Message 4 of 8 (1,667 Views)
03-22-2012 06:33 AM in reply to: sam_melvin
I verified that the xls works fine on my machine - so now we need to figure out what is different on your machine.
Active Member
sam_melvin
Message 5 of 8 (1,655 Views)
03-23-2012 01:02 PM in reply to: JDMather
Thats the same screen that I have, minus the drawing.
I have the free version for students but I dont think that should make a difference. Is there anything you need to do to prepare the sketch before you start importing points?
I have followed this tutorial to the letter, but it doesn't solve my problem. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8324557&linkID=9242018
The most annoying thing is that the window to choose the file just closes when I press 'open' and no error message appears.
before
after
I've just noticed that it has the option to 'Repeat Import Points', but when I undo, It closes the part like it would normally with a part that had nothing in it.
JDMather
Message 6 of 8 (1,651 Views)
03-23-2012 01:41 PM in reply to: sam_melvin
I am using the student version - it is fully functional.
New Member
firstpartsllc
Message 7 of 8 (1,316 Views)
02-09-2013 12:29 PM in reply to: sam_melvin
Your problem could be that Inventor needs to have excel installed to import the data. I had a similar but more severe problem with ProE. It would not even run without excel installed. good luck.
New Member
jellef1
Message 8 of 8 (1,193 Views)
03-21-2013 12:56 PM in reply to: sam_melvin
I am experiencing the same problem. I fixed it by having one of my friends sending an .ipt with the points already imported.
