I recently installed Inventor 2012 including content central. Someone has shared an assembly with me and I am getting some unresolved reference errors. I believe this is do to files that were creaeted from design accelerators.
Is there a way to correct these errors? Should Inventor be able to update the design accelerator parts when the part is opened?
The filename it is looking for is local.ISO.13.220.9.iprt
Any help on this would be appreciated,
Solved by whunter. Go to Solution.
Whoever shared the IAM with you didn't do a proper job to Pack and Go the assembly, the CC parts are sitting somewhere on a server, it seems.
If their content centre filenames doesn't match yours exactly, you're pretty much stuffed. Ask them to send the file again using Pack and Go, then you'll have his CC files too.
Thanks you for the response!
The guys who sent them to me did the pack and go but he selected the option Keep Folder Heirarchy. That was what was giving me all the errors trying to find the parts.
When we did Copy to a Single Path from Pack and Go everything worked.
Is there a reason the folder heirarchy selection does not work from Pack and Go. Just curious.
Thanks again
Thanks again
There should have also been a project file (*.ipj) in the pack and go.
Did you set this as the active project before opening the assembly?
The CADWhisperer YouTube Channel
