MDTR6 SP4 installed. still won't let me do it.
Gary M. D'Andrea
Drafter A
Mestek, Inc
Koldwave / Spacepak
413-564-5512
"Mike Gauvin" wrote in message
news:3FBA5535D78467CB8302EC0A077A336D@in.WebX.maYIadrTaRb...
> Mark is right. It's essential that MDTR6 has SP4 installed!
> Mike Gauvin
> INCAT
> "Gary D'Andrea" wrote in message
> news:122CFA2AF191963D0A8843CCF7ABA47B@in.WebX.maYIadrTaRb...
> > I just upgraded to SP2 for IV. tried to translate, didn't work. Tried a
> > repair on the program, still didn't work. Another guy here with same
> > settings as me can translate without a problem. Is there a setting to
> allow
> > translation? The funny thing about I was able to do it before. I opened
> MDT
> > and saved, then tried nothing. tried closing before opening in IV
nothing.
> > It will let me translate to a 2d idw. When I click on options I can't
pick
> > anything except AutoCAD or AutoCAD Mechanical file. It even tells me
> > "opening this MDT file using AutoCAD options does not allow import of
the
> > assembly structure or parametric models". So it is recognizing it as an
> MDT
> > file but I can't tell it to use it as a MDT file.
> > Gary M. D'Andrea
> > Drafter A
> > Mestek, Inc
> > Koldwave / Spacepak
> > 413-564-5512
> > "Mark Case" wrote in message
> > news:CB99655FD5AB4652446A4A0DC5AFFB3A@in.WebX.maYIadrTaRb...
> > > Hello Gary,
> > > It is VERY important that you have the latest service pack in MDT and
> > > probably not a bad idea to have the latest Inventor SP. I haven't
done
> a
> > > lot of translations in V6, but in the past the service pack was the
most
> > > important thing. I'm sure you saved after opening in MDT... I hated
to
> > > ask, but it's important.
> > > If it's not to big, put a copy out in customer files and I'll give it
a
> > > try...
> > > Mark Case, P.E.
> > > Sr. Mechanical Engineer
> > > CaseCAD Engineering
> > > (509) 773-7305
> > > web: http://w3.gorge.net/casecad
> > > news:1CBCF1D6C0E877C2228845E0B1D89059@in.WebX.maYIadrTaRb...
> > > > tried that still nothing. it won't let me translate any files.
> > > > Gary M. D'Andrea
> > > > Drafter A
> > > > Mestek, Inc
> > > > Koldwave / Spacepak
> > > > 413-564-5512
> > > > "Kent Keller" wrote in message
> > > > news:231A468FEE52F04E1B8221383A1CEC6A@in.WebX.maYIadrTaRb...
> > > > > Try opening it in MDT first and then doing the migrate.
> > > > > Kent
> > > > > Member of the Autodesk Discussion Forum Moderator Program
