Having a specific font style (Handel Gothic) which is used for our company logo i find that this does not seem to be supported by Inventor.
I have attempted to import .dwg drawings into inventor with the logo but this does not work.
Another method i have tried is to draw the characters in sketch mode and then attempt to solid hatch them again with little success.,there does seem to be no facility for hathing in sketch mode!
This logo font is used on our drawing border sheets and also nameplates so our MD is keen to keep the present format.
Any suggestions please.
I downloaded your Font from this site:
http://www.fontpalace.com/font-download/Handel%2BGothic/
(first result in google search)
It is a truetype font, so it shouldn't be a problem using it in inventor.
I had no problems placing text in a sketch on an .idw, see screenshot:
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
TTFs are managed by the operating system, so they will need to be installed for use by the various programs.
Niels van der Veer
The Netherlands
By the comment in the original post - "import font" then could it be a user moving data over from AutoCAD to Inventor and trying to get the same fonts with both programs?
As has been mentioned - Inventor uses Window's fonts, these are ttf files which are installed to c:\windows\fonts
If the original font is a shx (is that it, can't remember) AutoCAD font then it will not work with Inventor - you will need to find an equivalent ttf file and use that.
If you are only wanting a company logo on the border then you could import a dwg or use an image, but if you're after a font to be used throughout the idw/drawing then you will need to find a ttf.
Hope that helps
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Niels van der Veer
The Netherlands
m8, tell me about it... Anytime I need to boot up AutoCAD or MDT I'm staring blankly at the screen trying to work out what to do next.
Sam M.
