Inventor Forum
Importing Excel coordinates to Inventor
5 REPLIES 5
emaliutis
1664 Views, 5 Replies
Hello everybody,
I can't find import points command at 2D sketch mode. I do right click at toolbar / customize / commands / 2D sketch and there is no import points. I run Autodesk Inventor 2007. Is this version supports this?
Thanks in advance
5 REPLIES 5
Cadmanto
in reply to: emaliutis
Welcome to the forum.
I just started using Inventor in 2011.
I have to ask, if you are using 2007 Inventor, what version of office Excel are you using?
It doesn't look like this command was around in 2007.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17368641&linkID=9242018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
emaliutis
I use MS Excel 2003. Looks like Autodesk Inventor 2007 does not support insert points command. I just want to draw a wing cross-section :bla bla. I'll try to find another way to do it by 2007.
Thanks a lot
JDMather
Can you post a screen shot in the 2007 sketch environment.
I think it was there, somewhere, but need a jog of memory.
jletcher
in reply to: JDMather
If I remember this has to be done in 3d sketch mode. If you want it on a 2d level in the Z column make them all the same like all Z to be 0
I don't think the 2d import came till 2008-2009..
But as JD I  don't remember long time ago if I was there I could tell you or take screen shot like JD asked for.
emaliutis
