Inventor Forum
Importing a Solidworks ****. into Inventor
13 REPLIES 13
Message 1 of 14
michael.ruddy
16399 Views, 13 Replies
I need to import a Solidworks 2011 ****. file into Inventor 2010. I used the .step file format and when I opened it in Inventor all the mates were gone. Also all the colours of the different parts had gone.
Can anyone suggest a file format to use where most importantly the mates won't be lost and also where the colours won't be lost.
Mike.
13 REPLIES 13
Message 2 of 14
**** = Assembly. It didn't come up for some reason.
Message 3 of 14
Hi...you never will get the assembly constraints when you import other cad data.  That's the hard side when we work with different applications. When we import STEP, Catia, ProE, Solidworks...bla bla bla.... we always will get by default a dead body... Without model features.
But....the colors must be the same as the original file.... even in STEP format.
Soooo.....STEP its the best choice to your case.
I think that only Inventor 2012 can open Solidworks 2011 native data.
Asidek Consultant Specialist
www.asidek.es
Message 4 of 14
Thanks for that. Yes you are right one can only open a solidworks model in Inventor software that is a year ahead of the solidworks the models was last saved in. (prehaps also the same year as the SW although I am not sure.)
Message 5 of 14
To be sure....e went to my Inventor 2012 Help ....witch says:
Open and change models created in SolidWorks (versions 2003 - 2010). Autodesk Inventor translates assembly and part files, solids, multi-solids, surfaces, and more. After the import operation is complete, you have a base feature or features which match the geometry and topology of the original file. Use Autodesk Inventor commands to adjust the base features and add new features to the feature tree.
These types of SolidWorks files can be imported:
  • *.prt, *.sldprt (part)
  • *.asm, *.sldasm (assembly)
www.asidek.es
Message 6 of 14
Thanks for that. I am new to Inventor and trying to fumble through it. It seems to be awkard to move and rotate the part. It is not intitutive at all. Is the best way of moving the part using the orbit steering wheel or is there a better way?
I have no spaceball at the moment is it worh getting one?
Message 7 of 14
JDMather
in reply to: michael.ruddy
You can use Shift Wheel
or
beter yet,
get a 3D Connexion device.
Message 8 of 14
michael.ruddy
in reply to: JDMather
is shift wheel the wheel that is in Inventor at the right hand side?
Message 9 of 14
JDMather
Hold down the Shift key on the keyboard and at the same time hold down the mouse wheel (similar to SWx).
or
you might try F4.
Message 10 of 14
You will enjoy the Inventor, is very friendly application. Trust me.
If you need to rotate a component, you can do it with F4 or Shift+ mouse wheel button (as AutoCAD do) or..... the best option is undoubtedly is to use a space mouse...I have the Space Traveler (www.3dconnexion.com/)  and not live without it...its almost my best friend 😄
www.asidek.es
Message 11 of 14
Thanks for that......I hope it is as friendly as you say 🙂
Message 12 of 14
Service Pack 1 for Inventor 2012 added support for importing native SolidWorks 2011 files. It is still true that they are base solid like STEP, IGES, etc but it saves you the step of exporting to another format.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019
Happy Inventing!
Patrick Miller
User Experience Designer
Fusion 360 Learning
Message 13 of 14
pachecom_eng
in reply to: MariaManuela
Ola Maria Manuela. Sou o Pacheco e me encontro no Brasil.
Estou tentando importar arquivos do Solid Works e até consegui porém as peças perdem sua arvore original e portanto não consigo editar porque elas vem em forma de bloco. Vc pode me auxiliar?
Message 14 of 14
MariaManuela
in reply to: pachecom_eng
Olá Pacheco,
Tudo o que está a fazer está correctissimo, é mesmo assim.
Quando se abre ficheiros de outros softwares parametricos (caso Solisworks, CATIA, Creo, Unigraphics....etc...) o histórico é perdido.
Isto funciona assim em todos os softwares, daí se chamar "corpos mortos" a estes modelos importados.
Contudo, a Autodesk tem uma aplicação (gratuita apenas para clientes com subscrição) cuja se chama Feature Recognition a qual serve exactamente para que o Inventor faça reconhecimento das operações (Holes, Extrudes, Revolves..etc). Esta aplicação funciona muito bem e não é exclusiva para modelos de Solidworks, mas sim para a maior parte dos modelos paranetricos não Inventor.
Espero ter ajudado.
Junte-se ao grupo de Inventor em https://www.facebook.com/groups/307416559366491/
www.asidek.es
