Inventor Forum
Importing a dwg into a ipt.
14 REPLIES 14
Message 1 of 15
Cool_Breeze_Jr
2175 Views, 14 Replies
Just upgraded to IV 2014 and cannot import a dwg into a part file. I click the icon labeled ACAD within the Insert panel, I am able to select which dwg to import b ut after that it seems as if i never clicked the ACAD icon at all. Any suggestions?
Have installed svc pack 1....
Chris Biggs
Engineer/CADD Services
New Horizons RV Corp.
2401 Lacey Drive
Junction City, KS 66441
Dell XPS 8300
Intel(R) Core(TM) i7-2600 CPU@3.40GHz
16GB RAM
Win 8.1 Pro
Autodesk Product Design Suite 2014
14 REPLIES 14
Message 2 of 15
blair
in reply to: Cool_Breeze_Jr
I believe you need to have "DWG TrueView" installed on your system as well.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 15
Cool_Breeze_Jr
in reply to: blair
Yeah I checked that, it is loaded and working.
Chris Biggs
2401 Lacey Drive
Dell XPS 8300
16GB RAM
Win 8.1 Pro
Message 4 of 15
mcgyvr
I see Windows 8.1 in your signature..
I wouldn't be surprised if that was the problem...
Why all you nerds had to immediately load 8.1 is beyond me.. Smiley Tongue
I see there is a hot fix for autocad because after 8.1 you can't import anything...wouldnt' be surprised of the same problem isn't effecting Inventor too..
Have you tried to repair install Autocad and Inventor programs after the 8.0 to 8.1 install? just checking..
Others have the same problem.. Seems like 8.1 strikes again..
http://autodesk.lithium.com/t5/Inventor-General/When-inserting-importing-DWG-files-into-Inventor-not...
I'd submit a trouble ticket with autodesk support ASAP
Message 5 of 15
blair
At which point is it failing. Can you get the request DWG file dialogue box. It does take a bit to open. Possibly check your Add-Ins that the DWG translator is available.
Delta Tau Chi ΔΤΧ
Message 6 of 15
blair
in reply to: blair
Get the update 1 for SP1 for Inventor, this should help with 8.1 woes. That portion of your post was cut-off on my machine. Also select the Inventor Icon and RMB on it and select the Run as Administrator. Also seen some problems with user rights and CC with 8.1 where you need to turn off the UAC.
Delta Tau Chi ΔΤΧ
Message 7 of 15
CESAR200
It may be that Inventor is not fully registered with the operating system.  Please try the procedure below to correct the situation:
1) Press [Windows] key to open Windows' start page
2) Type "cmd" to find "Command Prompt" > right mouse click on it > select "Run as administrator"
3) On "Administrator: Command Prompt" window, type cd "c:\program files\autodesk\Inventor 2014\bin" > Enter
4) Type inventor /install > Enter
5) Wait for 1 min (inventor will be executed background then exit silently)
Cesar Valencia
Product Support
Autodesk, Inc.
Message 8 of 15
Luna84
in reply to: CESAR200
Hello, I have the same problem, but your solution dosn't help me. I use Windows 7, 64bit and Inventor 2014 with the german language pack. Can you help?
Message 9 of 15
db1116
I tired the linked solution above (did everything as I supposed), but when I type inventor /install it says 'inventor' is notrecognized as an internal or external commad, operable program or batch file.
I'm using an Inventor 2014 student version under Windows 8.1 64bit.
Does somebody know how to fix it?
Message 10 of 15
JDMather
in reply to: db1116
Post screen shot of you screen at this step.
Message 11 of 15
db1116
in reply to: JDMather
Message 12 of 15
JDMather
in reply to: db1116
Browse to the same path location using Windows Explorer.
Do you see an Inventor.exe and .ini?
Message 13 of 15
db1116
No I can not see anything, but I installed the software on one of my other partitions.
Message 14 of 15
db1116
in reply to: db1116
I reinstalled Inventor to my C: drive, and now the solution works correct! I was able to save as an AutoCad dwg!
Thanks for your help!
Message 15 of 15
yuri.rj
worked for me
