Inventor Forum
Importing a dwg into a ipt. and scaling
15 REPLIES 15
Message 1 of 16
SteveFrey
4128 Views, 15 Replies
I have a .dwg that I need to import into a .ipt file.  My problem is scaling the new part.  The .dwg is in mm and I need it to be in Inches. I forget how this is done.  Can someone explain?  Thanks.
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
15 REPLIES 15
Message 2 of 16
JDMather
in reply to: SteveFrey
Is it a 2D sketch or 3D geometry?
Message 3 of 16
SteveFrey
in reply to: JDMather
2D
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 4 of 16
yannicknielsen
I believe you can force it to import it as inches. Not sure, however, if it imports it as 25mm being 1 inch, or 25 inches.
Product Design Suite Ultimate 2021
Message 5 of 16
JDMather
@SteveFrey wrote:
2D
I would convert to Inventor Sketch Block - then it is easy to scale (if needed) and place anywhere desired.
Units can be handled in several ways, including -dwgunits (with the - sign) in AutoCAD.
Message 6 of 16
SteveFrey
Hi JD.  This is the part I need a little "how to" instruction.  Converting to a sketch block seems simple enough but I can't figure out how to scale something.  Can you assist on this?
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 7 of 16
SteveFrey
I think I figured it out.  Since the part I was importing into Inventor was 86 mm wide it showed up as 86 in. once imported into a standard .ipt template.  I edited the sketch dimensions and did 86/25.4 which is the conversion to inches.  Now it's the correct size.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 8 of 16
Hi SteveFrey,
If you have AutoCAD, you can select the geometry to import in AutoCAD and choose Copy (Ctrl + V), then switch to Inventor and choose Paste (Ctrl + V). You'll see a bounding box at your cursor before you click to place the geometry. It is at this point that you can right click and choose Paste Options and choose the units to use scale the geometry.
Paste Options dialog box
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-F7601F0D-21B8-4746-B37D-A80429CA73E2
Copy AutoCAD data into 2D sketches
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-4C473C5C-0AA5-4DB9-9C64-17956CA9111D
If you don't have AutoCAD and are using Inventor's Import "wizard", then you should have an opportunity to choose the units in the Layers and Objects Import Options dialog box.
Import AutoCAD data into Autodesk Inventor part or drawing
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-9996B399-313F-4AC2-9E39-B92CE5112F30
I hope this helps.
Curtis
Message 9 of 16
mdavis22569
why not save a 2nd DWG .. copy out the mm drawing into a Inch dwg and scale it ...then import it into Inventor 25.4 ...poof done
Mike Davis
Message 10 of 16
Now that makes it really easy!  Thanks!
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 11 of 16
SteveFrey
in reply to: mdavis22569
What I can't figure out is how to use the scale tool.  I can't find any instructions on how to do this.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 12 of 16
Hi SteveFrey,
If I recall correctly, you can't scale a sketch block, but you can scale "loose" sketch geometry. If the scale is not a straight units conversion, my preference is to scale in AutoCAD and then paste into Inventor, and then make it a sketch block.
Scale sketch geometry
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-8E9190C1-6C82-45B9-A05A-25C8AE1F3254
I hope this helps.
Curtis
Message 13 of 16
I remember scaling in AutoCAD was easy (but I don't remember how).  Maybe that was the question I should have asked in the first place.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 14 of 16
Hi SteveFrey,
In AutoCAD:
  1. Type SCALE (or SC ) into the command line, or click Home tab> Modify panel> Scale.
  2. Select all of the geometry to be scaled.
  3. Specify the base point by selecting a point on screen.
  4. Enter the scale factor into the command line.
I hope this helps.
Curtis
Message 15 of 16
In my case I'm trying to make a part that measures 86mm to be the equivalent size in inches.  Normally to figure this out you would divide 86/25.4.
I can't seem to make this work.  What would my scale factor need to be?
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 16 of 16
SteveFrey
.0393700?
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
