Inventor General Discussion
Active Member
dwhamm
Message 1 of 5 (307 Views)
Imported Stp file for FEA
307 Views, 4 Replies
11-26-2012 11:52 AM
I have been given several drawings to perform FEA analysis.  These files are solidworks files, but my school does not have the FEA package so I had to export the files to a .stp file to import it into Inventor.
On top of that, the SolidWorks file I need to analyze is an assembly, so I 'saved as' the assembly in Solidworks as a part to have one solid part.
The file seems to import fine at first, I can create sketches onto faces.  But when I go to create an analysis, and try to set a fixed point or force load, I cannot select a face.  I tried to "cheat" and add some material to the faces I wanted to use.  When I run the analysis, it just doesn't recognize the initial material in the 'mesh'.
I CANNOT include full screenshots of the system, due to the nature of the project.  I can show small clipped shots of the software status, but not the drawing itself.  If seeing the "model" box on the left would help, I can supply that with the drawing names blacked out.
Do not save in SWx as a single part - you want it as an assembly in Inventor.
Most likely your attempt to convert to single part STEP in SWx resulted in a surface body on import into Inventor rather than a solid body.  You can easily check this at the top of the browser or simply try creating a hole feature in the "part".
Cadmanto wrote:
Welcome to the forum.
I agree with JD.  You are going to want to save the individual files out of SW as parts.
No, simply save the SWx assembly as a STEP file.
Inventor will automatically create an assembly and the individual parts with the parts in the correct locations in the assembly (minus assembly constraints).
JDMather
Message 2 of 5 (304 Views)
Re: Imported Stp file for FEA
11-26-2012 11:59 AM in reply to: dwhamm
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Cadmanto
Message 3 of 5 (295 Views)
11-26-2012 12:37 PM in reply to: dwhamm
Then bring those files directly into Inventor and reassemble them (that is if the versions of SW and Inventor are compatible).  Then run your FEA analysis.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Active Member
dwhamm
Message 4 of 5 (277 Views)
11-26-2012 01:09 PM in reply to: Cadmanto
Hey Guys,
Thanks for all the help, I don't have access to the software at my personal PC and have class for the rest of the day.  However, I will check in the next couple days and get back to everyone to let you know how it went.
Thanks again for all of the quick responses.
JDMather
Message 5 of 5 (269 Views)
11-26-2012 01:56 PM in reply to: Cadmanto
