Inventor Forum
Imported STEP file has a Weldcat0.bmp file as third party in the vault browser
1 REPLY 1
feremans
496 Views, 1 Reply
I'm using inventor 2014 in a network version with the vault.
In this version there is an irritating issue which I never had in 2013. When I'm importing STEP files and I want to check in those parts, the vault gives me an error message which says that the file "Weldcat0.bmp" is outside the defined search paths. It is possible to break the link to that file, but this is rather time consuming, especially when I want to check in a lot of those files.
Does anyone know why this file is attached to my imported parts and if it's possible to avoid that.
Thanks ahead.
Walter
1 REPLY 1
Yong.Jing
in reply to: feremans
weldcat0. bmp is one of the surface texture file used in Inventor.
As vault gives your some error alert, it means that this texture file path does not include in the vault checkin path. Please check the Lib or Content used in Vault.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
