Did you Auto Stitch and Promote? If not, you will have to stitch and promote
construction geometry manually for each part. If you have many part files, it
might be easier to re-import the STP file. After choosing file, pick options and
check "Auto Stitch and Promote"
If you did this originally, then you have a greater problem. Most likely,
surfaces are not good enough for Inventor to stitch together. You might have to
use a different software to get it stitched together. (MDT, Rhino, TransMagic)
Dave Jacquemotte
Automation Designer
