I'm trying to link an Excel sheet to a new assembly but it is only listing half of the sheet parameters. I have done this before with no issues. I've also imported another sheet and it works fine. I copied and renamed a sheet I know that works deleting the data from it and coping the data I want and I get the same results. This lead me to believe there is something wrong with the sheet. See attached file.
Gordon Rogers
Excel 2010
Windows 7
Inventor 2012 64 bit
Yep tried it same issue on my system.
AUTODESK I do believe it is time you fix this. It is long over due stop playing with the new interface that sucks and fix our issues.
AUTODESK I do believe it is time you fix this. ...
What is to be fixed? There is an error on logic on the spreadsheet -
blank cell is interpreted as end of data.
