Inventor General Discussion
Doug_DuPont
Message 1 of 7 (551 Views)
Imported Components Folders
551 Views, 6 Replies
04-04-2013 05:59 AM
I do not like this. We down load a lot of vendor models and this folder is growing so large. How do I managethis better. Too scared to delete any of these folders. There is a lot of non-Unique files in them.
Douglas DuPont
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
*Expert Elite*
Cadmanto
Message 2 of 7 (547 Views)
Re: Imported Components Folders
04-04-2013 06:09 AM in reply to: Doug_DuPont
Doug,
Any change you have Vault?
If you do, check them into the vault and rearange them there.  Then delete your local and when you check them out from the vault the directory structure will come along for the ride.  This wil take constant maintenance though.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
*Expert Elite*
Curtis_Waguespack
Message 3 of 7 (524 Views)
04-04-2013 07:48 AM in reply to: Doug_DuPont
Hi Doug_DuPont,
The only controls for this reside in the Import Options. To access these options first select the file you want to import and then click the Options button, you'll see the save options at the top of the dialog box.
Note that if you access the Import tool via the Manage tab > Import button, you won't get all of the options. So it's best to do this by using the Open button.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
mrattray
Message 4 of 7 (514 Views)
04-04-2013 08:21 AM in reply to: Doug_DuPont
I agree, I don't like that folder either.  I make it a self-impossed rule to immediately "file away" anything I import into an appropriate directory. I delete the "Imported Components" folder regularly, because I know that anything I actually kept and used is safely tucked away in another folder. Right now I'm the only user that actually does jobs in Inventor, so I'm going to have to come up with something else once other users start invading my workspace.
Mike (not Matt) Rattray
Doug_DuPont
Message 5 of 7 (509 Views)
04-04-2013 08:27 AM in reply to: Doug_DuPont
Your lucky, I have 30 engineers filling these folders that don't care.
Douglas DuPont
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
*Expert Elite*
Curtis_Waguespack
Message 6 of 7 (505 Views)
04-04-2013 08:31 AM in reply to: Curtis_Waguespack
Hi Everyone,
I just created an idea at the IdeaStation for this, please go vote and/or comment if you have a moment:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Make-Import-Options-Save-Configuration-and-Applic...
I hope this helps.
Curtis
Valued Contributor
nannerdw
Message 7 of 7 (486 Views)
04-04-2013 09:06 AM in reply to: Doug_DuPont
I keep a folder with all of the vendor parts that I download, and add it as a library to my projects.
This is the folder hierarchy that I use:
Folder: "Inventor Library"
     Folder: <VendorName>
          Folder: <ProductCategory>
               Folder: <PartNumber>
                    Folder: "Source Files"
                         File: <FileFromVendor>.<sat/step/etc.>
                    Folder: "Parts"
                         File: <VendorName>_<PartNumber>_"Part1".ipt
                         File: <VendorName>_<PartNumber>_"Part2".ipt
                    Folder: "Documentation"                          File: <SpecsFromVendor>.pdf      File: <VendorName>_<PartNumber>.iam
-Using Autodesk Inventor Professional 2012
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
