Dude,
Something went wrong...I would guess that the install of the anti protection
script did not work go over this again. INV WILL see it as a quadro when it
is done right. Let me know if you still cant get it to work...
Brian
"Jeremiah Schutte" wrote in message
news:140D6810A49EF916E7C07D8C376E64CD@in.WebX.maYIadrTaRb...
> Thanks Brian, I did that and it sorta works. Windows sees it as a quadro
2
> pro, and it feels faster, but inventor still thinks it is a geforce 2 gts.
> I am happy that it is faster, but I don't know why inventor does not
> recognize is as a quadro.
> "Brian Corbin" wrote in message
> news:C3578B13A3C1F5D34FAB39A1C2D16237@in.WebX.maYIadrTaRb...
> > *** Must be running Win2K - WinXP
> > ***Download and install the detonator driver version 41.03*** from
> > www.guru3d.com
> > *** Reboot***
> > Download Rivatuner from www.guru3d.com
> > look in the rivatuner folder there is a tree like this
> > Rivatuner\Patchscripts\NVSTRAP Antiprotection\NVStarp Antiprotection
> > w2k.rts
> > run this file
> > click the comtinue button then browse to winnt\system32\drivers and
select
> > the nv4_mini.sys file and run the script. (this removes the anti NVStrap
> > from the driver)
> > run rivatuner.exe
> > Click on the little button on the first page besdie the word customise
> > Click on customise low level settings
> > Click on NVSTRAP driver (if not there I had to reboot a couple of times
> > Click install nvstrap
> > Force quadro features on
> > ***reboot***
> > Your card should now be recognised as a quadro, and the speed is much
> > better...
> > After installing NVSTRAP. The big thing to check is if you
> > open a Inventor window then goto tools, app options, hardware, diag INV
> also
> > should see your card as a Quadro now not a geforce
> > You can never reboot to many times 😉
> > news:5A6F598834A8029086AE8DB452E3B7DA@in.WebX.maYIadrTaRb...
> > > Brian, I have been trying to do this and I cannot get it to work. I
> think
> > I
> > > am doing it wrong because I cannot find the "Detonator 30.xx to 40.41
> fix"
> > > and I get an error when I try to apply softquadro. Can you describe
> what
> > > nvstrap is and what I need to do to make my geforce 2 gts into a
quadro?
> > > Thanks,
> > > Jeremiah
> > > news:4C06BD43D17AD90B0AED341C7FE983AA@in.WebX.maYIadrTaRb...
> > > > After some much needed help from Unwinder here is how you can run
the
> > > newer
> > > > (than 30.30) nvidia drivers with rivertuner.
> > > > UNINSTALL NVSTRAP DRIVER FIRST!!!
> > > > Reboot
> > > > UNINSTALL NVIDIA 30.30 (Windows Add/remove programs)
> > > > Reboot
> > > > Run the Detonator 30.xx to 40.41 fix (Can be found at www.guru3d.com
> > > nvidia
> > > > files)
> > > > Reboot
> > > > Install the new driver (I used 41.03)
> > > > Reboot
> > > w2k.rts
> > > > run this file
> > select
> NVStrap
> > > > from the driver)
> > > > Now reinstall the NVStrap driver as usuall and reboot and you should
> be
> > > away
> > > > laughing....
> > > > Brian
