decided not to wait, did it, works great. Thanks!
"Paul Houlker" <666paulh@rimex.com666> wrote in message
news:3980DE4EAC8D30D94E044AB24D4AA039@in.WebX.maYIadrTaRb...
> Thanks!
> ill give it a try at lunch
> "Brian Corbin" wrote in message
> news:B0CC7EA8C1DB31FEDD413B00769EB135@in.WebX.maYIadrTaRb...
> > After some much needed help from Unwinder here is how you can run the
> newer
> > (than 30.30) nvidia drivers with rivertuner.
> > UNINSTALL NVSTRAP DRIVER FIRST!!!
> > Reboot
> > UNINSTALL NVIDIA 30.30 (Windows Add/remove programs)
> > Reboot
> > Run the Detonator 30.xx to 40.41 fix (Can be found at www.guru3d.com
> nvidia
> > files)
> > Reboot
> > Install the new driver (I used 41.03)
> > Reboot
> > look in the rivatuner folder there is a tree like this
> > Rivatuner\Patchscripts\NVSTRAP Antiprotection\NVStarp Antiprotection
> w2k.rts
> > run this file
> > click the comtinue button then browse to winnt\system32\drivers and
select
> > the nv4_mini.sys file and run the script. (this removes the anti NVStrap
> > from the driver)
> > Now reinstall the NVStrap driver as usuall and reboot and you should be
> away
> > laughing....
> > Brian
