Hi, I have created Template drawing files of D Size, C Size, B Size with defined title blocks and dwg sheet informaion on it. These template files i want to used in 2011 Solid Works . I dont want to again create the Title Blocks , Border layout and Sheet information for Solid Works. How can i import or make use of ready templates created in Inventor to SolidWorks. ?
Shrikant Murkute
Solved by VinodBalasubramanian. Go to Solution.
I don't think its possible directly from Inventor at the moment. However you could try saving the Inventor drawing templates into an AutoCAD drawing and then try bringing it into Solidworks. This might help you a bit.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi.. I have the same issue.
I did the AutoCAD file from inventor and taken to Solidworks. so i need to make all the templates settings as per the 'style editor' like in inventor .
