I created a custom CC part edited the table to create larger and smaller versions of the same part. I found a mistake after I was finished and fixed the mistake on the original part. When I go to replace the family template it gives me an error message stating that the "import part is invalid" I have tried modifying the original, importing the part from the CC modifying it and telling it to use that one as a replacement with the same effect. Is there a way to replace the original part I used or am I stuck deleting the family and starting over because of one dimension?
