I have a drawing in AutoCAD 2013 with carefully laid out hatch patterns for traced text using clean, closed, non-overlapping, polylines only. (with islands in the holes). When I import this into Inventor sketch the hatch comes through but the islands do not. Such as the 0 gets completely filled in. I don't have the ability to edit this hatch and add the islands.
I can import the dwg without hatch and fill it within Inventor, but I need to have all the enpoints constrained, or the Fill command won't reconginze the boundaries. If I import this with contraining the endpoints, then the import takes a very long time (I gave up after waiting 5 minutes).
Does anybody have any ideas that can help?
jvj
Can you attach the AutoCAD dwg here?
Thus far, I have separated everything not hatched from the company name, and import the 2 separately. When I imported the company name with constrained endpoints, I had to maticulously hatch each character of text within inventor. In AutoCAD I had it all hatched using the hatch by selection mode (solid fill, colors 17,17,17 and 0,17,10)
jvj
It imported almost instantly for me.
I would do as three parts
1. the logo and sketch text
2. the train logo
3. the typed text
First I converted what I think is the area you wanted to Hatch/Fill to a block in AutoCAD.
@Anonymous wrote:I had to maticulously hatch each character of text within inventor
Maybe I missed something.
It only took 2 or 3 minutes.
I have a similar problem. The company logo I am to use was given to me in Autocad where it is hatched properly. However when I import it into the Inventor 2013 titleblock it imports but I cannot hatch it. Could anyone help me out as to how to close the geometry I was given without re-creating the logo? Also I am curious to know if anyone gets it to work as is in 2013.
Thanks in advance
