Hello
I am just trying to find a way to import a dwf file into inventor as a dummy model.
I want to be able to create/assemble parts around the dwf model and make sure they fit.
I was hoping to save having to put the files into Navisworks and constantly check for clashes...
Any ideas?
I don't believe you can bring a DWF into any of the native CAD programs from which they are created. A STEP or IGES might work better for you if all you want is a "dummy" model. My question would be, if you have a DWF... do you have the original model that it came form? If so you can create one of these formats that will work in Inventor.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
This works for 2D. I don't know about 3D.
http://anydwg.com/dwf-to-dwg-home.html
