I'm working on homogonizing all of our various templates, making all the new features from newer templates available in the older templates but I'm getting high centered on a step.
I've exported all of the different drawing standards and imported them all into each template which makes all of the upgraded dim styles available in all of the templates. The issue arrises when I save and close then reopen the template the imported standards are missing. It appears that under Manage, Styles Editor, if the standard is not in use it is not saved with the template. If this is the case how do I put them all "in use"? Even if I activate one of the imported standards, save, close, reopen, then activate a different standard and repeat, the imported standard is deleted.
Eric
Solved by Curtis_Waguespack. Go to Solution.
If you have saved all the standards and styles to the library, they should be available in your templates, I would think.
Don't use vault here so I'm probably not much help.
They are available from under the "All Styles" tab of the styles editor but not from the parts list style pull down, I'm trying to make them i"in use" in each template so that they are readily available to my users.
Eric
Hi ebuckner,
Without looking and stepping through the process first hand, I'm a bit unclear on the issue. But I think there are 2 things to try:
I might be missing the mark, so just post back if these things don't help.
I hope this helps.
Curtis
