Hey,
When importing .sat files for example, a sketch is created in every part file.
Those sketches are empty except a single point at the origin coordinates.
The sketches are allway visible in the parts.
This is irritating in an assembly.
Is importing possible without creating those sketches in every part file?
Kind regards,
Jan
Hi! I must have done something different. I am not seeing the behavior. Could you attach a SAT file here or send it to me directly (johnson.shiue@autodesk.com)?
Thanks!
No sketches are created for me either..
janlsing.. Try opening this sat file (right click.. save link as) https://dl.dropboxusercontent.com/u/9726802/Autodesk/84835A210.SAT
Are you just using "open" to open these files.or something else... if so post your sat import options screenshot.
Here is what I see.. notice no sketches and my iam is named the same as the sat file..
see attached
Solved!
Got the answer:
It is the Standard.ipt template you are using. I bet the template file has been edited and a sketch was added and saved. Then when you import SAT file, Inventor use Standard.ipt as the template. It just carries over the sketch.
Thanks guys!
