Inventor Forum
Imates in Iassembly
4 REPLIES 4
360 Views, 4 Replies
Imates in Iassembly
I have made an Iassembly and added Imates. When placing in an assembly the Iassembly moves to the right position but when confirming with left mouse button I get a error message. WHY?
4 REPLIES 4
Forgot.
Build 320, Inventor 2008, sp2
Soon changing to Inventor 2009.
Here I made an example of my problem
When I try to insert the test samman.iam into the samman.iam and use imates I get the General error message.
Anyone else have this problem?
gpoorman
I took a look at this using Inventor 2009.
This is most curious. When I used your files in the ZIP I did, indeed, see
the error you described.
I'm curious as to how the data was created though. After seeing the error, I
deleted the tables turning
the iAssembly back into a normal assembly. Then I re-created the table
EXACTLY how you had it
and repeated your steps and the error went away.
I then tried the exact steps I described above using Inventor 2008 SP2 and
saw the same results.
Glenn
wrote in message news:5920783@discussion.autodesk.com...
It works deleting the table and adding it again.
Thanks.
First I made the assembly to an Iassembly and then added Imates.
Looks like first I need to add imates and then turn it into an Iassembly. Tried to remove and add imates to the Iassembly and then I get the same error message.
