I took a look at this using Inventor 2009.
This is most curious. When I used your files in the ZIP I did, indeed, see
the error you described.
I'm curious as to how the data was created though. After seeing the error, I
deleted the tables turning
the iAssembly back into a normal assembly. Then I re-created the table
EXACTLY how you had it
and repeated your steps and the error went away.
I then tried the exact steps I described above using Inventor 2008 SP2 and
saw the same results.
Glenn
wrote in message news:5920783@discussion.autodesk.com...
Here I made an example of my problem
When I try to insert the test samman.iam into the samman.iam and use imates
I get the General error message.
Anyone else have this problem?
