Inventor Forum
iMates and wouldn't it be cool if
10 REPLIES 10
Message 1 of 11
152 Views, 10 Replies
Wouldn't it be cool if there was a hole tool like what Ryan and Drew made, built into
Inventor, and it also automatically added a named imate when you made the hole. Then in
assembly mode you would just have to insert your iParts with pre setup imate names that
matched and everything would fall together.
Kent
Member of the Autodesk Discussion Forum Moderator Program
10 REPLIES 10
Message 2 of 11
Yup!
Or even better, if you could select your screw, bolt, or PEM and the correct
hole size is placed on your part.
Mike
"Kent Keller" wrote in message
news:51ED34CC4E8B15B4D8385AEE9AC1ABC0@in.WebX.maYIadrTaRb...
built into
hole. Then in
imate names that
> Kent
Message 3 of 11
MechMan_
Nice concept but would need to be configurable so that you don't get useless iMates placed on holes that don't have items inserted into them like a pattern of air holes in a vent or weight reduction hole cutouts. Also, which side of the hole gets an iMate?
MechMan
Message 4 of 11
www.mechsoft.com
Rory
"Mike Maenpaa" wrote in message
news:9745080A4D9E8FC96D0AC3D5B35D5524@in.WebX.maYIadrTaRb...
> Yup!
correct
> Mike
Message 5 of 11
That would be simple. It would just be another column on the table and you could add a
imate name or not.
The side that the hole sketch is on would be what I would expect for the side to get the
mate.
Kent
"MechMan" wrote in message news:f12a09f.1@WebX.maYIadrTaRb...
> MechMan
Message 6 of 11
MechMan_
Ah, Kent. The visionary at work.
MechMan
Message 7 of 11
What are you sitting here dreaming about? Get to work on that add-in
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
news:63E7A8A66F9EEC1118F165FFCCAE74C9@in.WebX.maYIadrTaRb...
you could add a
> imate name or not.
side to get the
> mate.
> Kent
useless iMates
air holes in a
an iMate?
> > MechMan
Message 8 of 11
I think he's hinting he want's us to do it ;(
c'mon Kent, theres a free copy of IVHOLES in it for you 🙂
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Visit my MCAD website @ http://www.mymcad.com/
"Sean Dotson" wrote in message
news:ACD134C495A0EB9A3B6C2E42739AA8CC@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> you could add a
> > imate name or not.
> side to get the
> > mate.
> > Kent
> useless iMates
of
> air holes in a
> an iMate?
> > > MechMan
Message 9 of 11
shouldn't that be an assembly feature?
K
> Yup!
correct
> Mike
made,
> built into
the
> hole. Then in
> imate names that
> > Kent
Message 10 of 11
Thanks Rory! I finally got a chance to look at this. Looks good, but money
(lack of) is an issue. $2400 is a bit much.
Mike
"Rory" wrote in message
news:EF18DFEE0758E36933F00E51CBDE8777@in.WebX.maYIadrTaRb...
> www.mechsoft.com
> Rory
> > Yup!
> correct
> > Mike
Message 11 of 11
Karl,
No. Assembly features don't modify the actual .ipt file. During part design,
I would like to be able to pick a PEM nut,stud,etc. and have the appropriate
hole placed on the .ipt file, plus since this PEM has to be added in the
assy, add the insert constraint at the same time.
Mike
"Karl Maas" wrote in message
news:3AA0815C9C596977FA402A6FB9711748@in.WebX.maYIadrTaRb...
> K
> > Yup!
> correct
> > Mike
> made,
> > built into
> the
> > hole. Then in
> > imate names that
> > > Kent
