Inventor Forum
IMates and the Content Center
1 REPLY 1
LOONYLEN
528 Views, 1 Reply
Ok so I looked all over this message board to find out if I can edit Content Center iParts' IMates.
I added a screw to the Content Center and now I would like to add an IMate to it.
Does anyone know how this is done?
Senior Designer/Cad Administrator
Inventor 2012, w/SP2
Vault Collaboration 2012
Dell Precision T3500, Intel Xeon CPU
W3680 @3.33GHz, 16.0 GB of RAM
Microsoft Windows 7 Pro, 64 Bit Edition
Version 2009, w/SP1
1 REPLY 1
alessandro.gasso
in reply to: LOONYLEN
Please, try the following.
  • Open from Content Center.
  • In the open from Content Center dialog, double-click on the family of the screws you have published and insert one of them with the option As Custom.
  • Save the file in a location on your machine.
  • When the file is open, add the iMate and save the file.
  • Menu Manage > Content Center > Content Center Editor.
  • In the Library field select your custom library from the drop-down menu.
  • Select the family of the screws you have published, right-click, Replace Family Template.ReplaceFamilyTemplate.png
  • In the following Open dialog, select the file you have saved at step above.
I hope it can be helpful.
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
