Inventor General Discussion
Distinguished Contributor
gcross
Message 1 of 9 (735 Views)
Image tool grayed out in IDW-Bug?
735 Views, 8 Replies
10-10-2012 10:37 AM
Using Inventor 2012 latest SP
My Image tool icon is grayed out in Insert Panel of the IDW.
I created a sketch in the IDW & have no way to insert a graphic.I checked multiple files including a new file forma template & cannot get the Image icon to work, it's always grayed out.
 Is there an option setting I need to change?
We really should have the ability to cut & paste into IDW's.
Gary
Product Design Suite Ultimate 2014
Hi gcross,
I think it's always been that way. But you can create a Sketched Symbol and insert an image into it.
I hope this helps.
Curtis
Curtis_Waguespack
Message 2 of 9 (727 Views)
Re: Image tool grayed out in IDW-Bug?
10-10-2012 11:28 AM in reply to: gcross
Hi gcross,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
nstalker
Message 3 of 9 (610 Views)
03-07-2013 11:30 AM in reply to: Curtis_Waguespack
In sketch mode my image button is greyed out.  I can select ACAD or Points.  Why is image greyed out?
Curtis_Waguespack
Message 4 of 9 (607 Views)
03-07-2013 11:36 AM in reply to: nstalker
Hi nstalker,
You need to create a Sketched Symbol rather than just a sketch, then you can use the image tool.
I hope this helps.
Curtis
JDMather
Message 5 of 9 (604 Views)
03-07-2013 11:39 AM in reply to: nstalker
In drawing you can only put an image in a sketch in a Drawing Resources (Sketch Symbol, Border or Titleblock) sketches.
Expand Drawing Resources and Right Click on Sketched Symbol and the select Define New Symbol.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
nstalker
Message 6 of 9 (602 Views)
03-07-2013 11:40 AM in reply to: Curtis_Waguespack
Curtis,
Thanks for your response.  Can you direct me to a tutorial to create a sketched symbol?
Thanks!
Noel
JDMather
Message 7 of 9 (595 Views)
03-07-2013 11:44 AM in reply to: nstalker
http://download.autodesk.com/us/inventorprofessional/pdf/SketchedSymbols_stacking.pdf
nstalker
Message 8 of 9 (592 Views)
03-07-2013 11:49 AM in reply to: JDMather
hmm.  This isn't what I'm trying to do.  Sorry - I wasn't very clear.  I'm trying to make a sticker of something and place it on a part in Inventor.  So I thought I would offset a plane, create a sketch, insert and image and follow the rest of this tutorial:
http://www.youtube.com/watch?v=Lut3qzqbhQU
So ultimately I'm looking to put in a decal on my model, not in the drawing.  I may be in the wrong thread but if you could point me in the right direction it would be appreciated.
JDMather
Message 9 of 9 (590 Views)
03-07-2013 11:53 AM in reply to: nstalker
In the real world a sticker is a solid physical part with thickness you can hold in your hand.
Therefore model it like a solid - just like any other solid.
In the video they didn't model it like the real world - they simply used a Decal feature directly on the part.
If the part on which it will go is not flat (or some other simple shape like cylindrical) the Derive Component the part that the sticker will go on as a Composite surface to get started.
To make a Decal click here (after getting your image into a part sketch).
