Inventor General Discussion
Active Contributor
6 Kudos
Post 21 of 25
Re: iLogic workflow for suppressing / excluding components
11-26-2012 06:11 AM in reply to: sergelachance
Is "TR" a parameter in the same assembly as the iLogic rule?  Typically the parameters will display as the color blue.
As a test, insert the line of code
msgbox(TR)
and see what value the program thinks TR is.
If  TR is in a part or assembly other than where you are referencing it then you access it differently.  If this is the case look into:
Parameter("Part1:1", TR) = 1
or
Parameter(MakePath("SubAssem1:1", "Part1:1"), TR) = 1
-Shawn
3 Kudos
Post 22 of 25
11-26-2012 08:12 AM in reply to: Shawn_79
Thanks for your reply Shawn_79 :smileyhappy:
I know for the blue color now :smileyhappy:
the Multivalue text parameter is not linkable???
Active Contributor
6 Kudos
Post 23 of 25
11-26-2012 08:23 AM in reply to: sergelachance
I do not use many multi value parameters, but I would not expect them to work differently from any other parameter.
Did msgbox(TR) return the an expected value?  If it returns blank then you may not be referencing the parameter "TR" correctly in your code.  Did you type "TR" or access it by double click from the parameter table in the top left of the iLogic editor?
3 Kudos
Post 24 of 25
11-26-2012 08:41 AM in reply to: Shawn_79
all work great now, suppress all i want, but my biggest problem is  all my text parameter is not linkable???
all my parameter is in my frame sketch but i see only a numeric parameter, all text parameter is not here???
:smileysad:
Thanks again Shawn_79 :smileyhappy:
Active Contributor
6 Kudos
Post 25 of 25
11-26-2012 08:53 AM in reply to: sergelachance
Check out "Parameters Functions" for the iLogic help.  It will explain the various ways to access the parameters.
I have several text type parameters I access by code.  As an example I use Parameter("SKEL", "CoolingType") to reference CoolingType parameter in my skeleton part from an upper assembly.
-Shawn
