Inventor General Discussion
Valued Contributor
SteveX82
Message 1 of 25 (5,110 Views)
iLogic workflow for suppressing / excluding components
5110 Views, 24 Replies
10-07-2011 10:34 AM
I am working on an iLogic assembly configurator that manipulates several skeletal parts, and suppresses both standard and skeletal parts depending on the configuration.
I've been using the Component.IsActive function to suppress all omitted parts, which has prompted me to create a custom Level of Detail. This hasn't caused me much grief until I had completed ~10months of work when it was time for me to make my final assembly drawing and a parts list.
I am now running into several deal-breaking issues:
1) Suppressed parts insist on appearing on the Parts List.
2) Saving the assembly drawing reverts my assembly model to the "Master" LOD, which I never, ever, ever want to see again so long as I live.
Is there another workflow or technique that I should be using to turn off unwanted components in an assembly? I understand that LOD's are really intended to manage system resources, but Inventor users seem to be left with no other option to display a skeletal assembly in a certain configuration. What is the point of the Component.IsActive function if it doesn't update your assembly (at least so far as the Parts List is concerned)?
If I am left to deal with the nightmare that is the Inventor LOD, is there any way to set up the Parts List to reference the custom LOD?
Drawing View reps don't seem to be an option, as it looks like there is no way to automatically update the same custom view after the configuration has been made. The iAssembly Include/Exclude feature would handle part inclusion and BOM behavior nicely, but it won't fit into the rest of my iLogic and file management program.
Thanks for any suggestions you can provide,
Steve
The attached text file contains a rule that will check the current model browser tree for the following conditions and prompt to fix them:
Suppressed parts with an BOM structure not equal to Reference
Active parts with a BOM structure of Reference
Parts with visibiltiy turned off
It also includes provisions to ignore certain browser names such as "SKEL".  Virtual parts are also ignored.
We use this with our iLogic configurator in order to make sure the BOM reflects the model state.
All outputs are written using the trace.writeline command see the following thread for details.
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-Developing-and-debugging/m-p/2845670/highlight/true#M389808
-Shawn
Valued Mentor
rjay75
Message 2 of 25 (5,096 Views)
Re: iLogic workflow for suppressing / excluding components
10-07-2011 11:22 AM in reply to: SteveX82
iLogic has to have a custom level of detail when suppressing parts. (Usually named <iLogic>). Edit the base view of the assembly in the drawing.
In the drawing view dialog there is an option of which level of detail to select. This will also control which BOM to use for the parts list.
Check and see what setting the file open options is set to. Level of Detail should be set to Last Active. (Tools > Application Options > File > File Open Options) To get it to stay on the custom LOD switch to it and immediately save. Make sure that's the last active LOD when closing the assembly.
While opening an assembly you can also pick options and select the level of detail it opens up to.
Valued Contributor
SteveX82
Message 3 of 25 (5,091 Views)
10-07-2011 11:45 AM in reply to: rjay75
Thanks for your quick reply, Rodney.
Unfortunately, the behavior that you describe is not how my assembly and drawing behave.
When you get a few free moments, please try the following example:
1) Throw two random parts into an assembly file, but place one of them twice (for a total of three parts).
2) Suppress the second instance of the duplicate part, and create a custom LOD. Save and close.
3) Create a drawing and place a base view of your assembly with the custom LOD active.
4) Place a "Parts only" parts list....you'll notice the quantity is incorrect for your duplicate part.
5) Save the idw.
6) Open the assembly back up, and you'll notice it has reverted to the "Master" LOD despite your application options settings and last-saved-as condition.
I'm hoping you notice some sort of mistake in my example workflow, or an alternative method of making things work properly. The reversion to the Master LOD isn't exactly a deal-breaker as I last described, but it seems to be a bug that will end up annoying the hell out of the designers down the hall.
Thanks again for your help,
Steve
swalton
Message 4 of 25 (5,086 Views)
10-07-2011 12:01 PM in reply to: SteveX82
LODs are designed to not change the count in the BOM.
Would you want your count of screws to change when you suspressed all 10k in your assembly so you could fit that iam in 3 GB of ram?
My guess is that if you want to change the count of components in your BOM, you will have to delete them and save a copy of the new assembly or use iassemblies.
Inventor 2014
Vault Professional 2014
Valued Contributor
SteveX82
Message 5 of 25 (5,083 Views)
10-07-2011 12:13 PM in reply to: swalton
If LOD's are designed to not play nicely with iLogic, then I feel Autodesk ought to develop an alternative. At the very least, they could provide us with a Component.Include function that behaves similarly to an iAssembly.
What I'm really looking to do with this Configurator is to have a pile of parts in one assembly, and use iLogic (and only iLogic) to resize the skeletal parts as necessary and suppress/exclude/turn off/whateveryouwanttocallit any unnnecssary parts. Manually deleting parts after iLogic is done isn't an option, as it may be desired to include those parts at a later date.
Consider this example: we write a bunch of iLogic code to design custom Quonset huts based on a bunch of formulas that are too complex and varied for an iAssembly table. No two huts are the same, but they can come with or without a standard-sized window on the front. Are you saying that there isn't a way to use iLogic to include/excluse a simple window after it has managed to design the rest of the building?
swalton
Message 6 of 25 (5,079 Views)
10-07-2011 12:31 PM in reply to: SteveX82
You are fighting the way LODs are intended to be used.  You want to use them for configuration managment.  They don't work for that purpose because they do not change the BOM (by design from AutoDesk). The only use for an LOD is to remove some components from the stack of stuff that IV has to calculate and display at each regeneration.
It looks like if you want to change the BOM you get to use iAssemblies or adding/deleting the extra components from your assembly.
I figured that you would have the template assembly with all its ilogic rules and the "pile of components" stored on disk.  Your users would then copy the entire template assembly and all of its components to a new location on disk.  They would then run the configuration rules on the new assembly set.  The ilogic rules would delete or add components as requred by the code.  No issues with LODs and BOMs because you are not trying to supress stuff, you have removed it completely.
Inventor 2014
Distinguished Mentor
swordmaster
Message 7 of 25 (5,062 Views)
10-08-2011 09:29 AM in reply to: SteveX82
Steve,
The behaviour you are describing is not normal, I use ilogic and LOD,s to suppress/unsuppress components and the parts list ALWAYS shows the correct component quantity.
Here is my workflow
open a new assembly
create a new level of detail (i name mine ilogic as standard but the name is not important)
place 3 instances of a component
create a ilogic rule to suppress instances based on a user parameter
if
suppress_component = 1 then
Component.IsActive
("0061-181410-001:1") = False
Component.IsActive
("0061-181410-001:2") = True
Component.IsActive
("0061-181410-001:3") = True
elseif
suppress_component = 2 then
Component.IsActive
Component.IsActive
("0061-181410-001:2") = False
Component.IsActive
elseif
suppress_component = 3 then
Component.IsActive
Component.IsActive
Component.IsActive
("0061-181410-001:3") = False
else
Component.IsActive
("0061-181410-001:1") = True
Component.IsActive
Component.IsActive
end if
so by changing the parameter value i can control how many instances are active
save and close the assembly
start a new idw
create a base view
browse to the assembly file
select the ilogic level of detail from the drawing view interface
place the view
create the "parts only" parts list
quantity shown is the number of active instances
save idw and close
open the assembly (it opens in the ilogic lod )
change parameter value triggering ilogic rule which changes the instance quantity
save and close
open the idw
the parts list has updated to the revised instance quantity.
As i said i do this all the time with no issues. One word of warning is not to have the assembly AND the drawing open at the same time........this causes problems.
I am using INVENTOR 2009
Inventor 2010 Certified Professional
Valued Contributor
SteveX82
Message 8 of 25 (5,050 Views)
10-10-2011 04:48 AM in reply to: swordmaster
Thanks agian to both of you for your replies.
I've noticed that there is a difference in how the Parts List is affected by either manually suppressing a component VS using iLogic Component.IsActive to do the same.
* If a component is manually suppressed (as in my example), the parts list and quantities are "incorrect" and reflect the Master LOD's Parts List.
* If iLogic is used to suppress a component (as in swordmaster's example), then the parts list and quantities are "correct" and reflect the active custom LOD.
* In both cases, the assembly undesirably (at least in my opinion) switches to the Master LOD after saving the drawing, closing the drawing, and reopening the assembly. This causes all of the unneeded suppressed components to appear on the designer's screen until I remind them to manually switch back to the iLogic LOD. This process is repeated every time the drawing is opened and saved, and I'd really prefer for the assembly to just stay the way it was last saved.
If Autodesk intends for LOD's to control visualization and system resources only, then why are Parts Lists affected by one suppression workflow and not the other? Is this inconsistency also intentional?
Active Contributor
Shawn_79
Message 9 of 25 (5,036 Views)
10-10-2011 09:41 AM in reply to: SteveX82
The iLogic component.isActive also changes the BOM structure to REFERENCE which is what removes it from the BOM.  If you manually suppress a part you must first change the BOM structure to Reference for the BOM to be correct.
I have written two iLogic rules to help with this situation.  The first will perfrom the component.isActive = False to a selected item and the second reviews the assembly and checks for suppressed parts that do not have a Reference BOM structure and prompts the user to change them.  The first rule is shown below.  If you are interested in the second rule let me know and I will clean it up and post it.
'Suppress Selected Item
'Get currently selected component
Dim oOccurrence as ComponentOccurrence
Try
 oOccurrence = ThisDoc.Document.SelectSet.Item(1)
Catch
 MessageBox.Show("Please select a component before running this rule", "iLogic")
 Return
End Try
 'Set the selected item
oOccurrence = ThisApplication.ActiveDocument.SelectSet.Item(1)
Component.IsActive(oOccurrence.name) = False
You can also use ilogic code to set the current LOD.  We have noticed that Inventor will sometimes change to Master LOD (somewhat random, or at least I haven't picked up on the pattern yet.)
ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("iLogic").Activate
-Shawn
Active Contributor
Shawn_79
Message 10 of 25 (5,020 Views)
10-11-2011 03:36 AM in reply to: Shawn_79
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-Developing-and-debugging/m-p/2845670/highligh...
-Shawn
