Is there a way to work with parameters on a suppressed assembly using iLogic.
Everything works fine, but when I suppressed a part ilogic rule give me an error:
Parameter: The component named "xxxxx:1" was not found.
Mack
When a part is suppressed, it is essentially removed from the assembly and iLogic will no longer be able to find it. You won't be able to manipulate parameters in any suppressed components.
You will have to rewrite your code so that it isn't trying to access parameters in a component after it has been suppressed.
Post your code here if you would like some help rewriting it.
Cameron Whetten
Inventor 2014
Please click "Accept as Solution" if this response answers your question.
