Hi
I have an ilogic assembly that I change to different widths.
And I want ilogic to put the part number into the title block according to the size of the assembly.
What I have works but won't update on its own.
I have to open the ilogic rule and close it, then open the iproperties of the idw and close before it will update.
Any sugestions?
See attached
Solved by Jon.Dean. Go to Solution.
Solved by Retselnitram. Go to Solution.
Thanksfor the replybut I'm not ilogic pro.
don't understand 100%
Could you show sample or explain so aperson like me can understand?
You have to add a Event Trigger to your Rule like Theo said, so it runs the code whenever a parameter changes.
There are many examples on YouTube - http://www.youtube.com/watch?v=fltp0IXq64U
Jon
