I was wondering if anyone knew of a way to make all components in an assembly (.iam) file visible using the iLogic (not unsuppressed).
Basically what I want to do is run an iLogic rule on file open that will make anything that is not visible visible for the simple reason that we have designers here that will isolate something to work on it or look at it then save and close the file before undoing the isolation leaving the next person to open it the annoying task to pick through the thru the browser to make everything visible
Thank you
Hi ComputerGuru666,
You can find some code to do this at this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/select-hidden-parts-in-assembly/td-p/3298929/
But another board member named coreyparks, reminded us that Inventor has this ability built in without a need for an iLogic solution. (kudos again to coreyparks!)
I hope this helps.
Curtis
That code worked thank you very much Also does anyone know why you cant move patterned bolted connection in the componenet tree this also causes the "Alpha Sort Component" command to error out
Thank you
