Inventor Forum
iLogic - VESSEL
23 REPLIES 23
Message 1 of 24
2548 Views, 23 Replies
iLogic - VESSEL
23 REPLIES 23
Message 21 of 24
mrattray
in reply to: swordmaster
@swordmaster wrote:
Should make no difference Inventor will still handle the BOM status automatically
It does make a difference. When you manually suppress or unsuppress a part (via RMB) it does not effect the BOM status. When you suppress/unsuppress a part using IsActive from iLogic then Inventor does update the BOM status.
Mike (not Matt) Rattray
Message 22 of 24
swordmaster
in reply to: mrattray
I stand corrected!
Thats why i use ilogic to toggle suppression states
Inventor 2010 Certified Professional
Message 23 of 24
Parameter("Part7.ipt", "aaa") = 10
I had to add extension and capital letter, now it's OK
I noticed one thing, i do not have to export parameter to read/write it from assembly file, so what's the goal of using exported parameters? I see exported parameters in custom properties, anything else ?
thanks
marcinsoo
Message 24 of 24
mrattray
The only purpose for exporting parameters is to put them into your custom properties or for deriving. They don't have anything to do with iLogic.
